A930Rocket's Avatar
I changed the bulbs in my 14 F150 a year or so back, as the stock bulbs we pathetic it helped but adding an 18” LED light bar down low and wired to the high beams made all the difference.
Old 11-28-2019, 10:42 AM
FUSHIGI
Everyone appreciates being able to see well when driving at night. I'm not a spring chicken anymore and good bulbs make a massive difference even in my DD Subaru wagon running 80 miles a workday in winter dark. Not infrequently, a truck (9 of 10 times) running an LED light bar on the front blinds everyone going the opposite direction. Noting personal A930 and I get your's being wired to the highs but WTF? Truck lights are already twice the height of any car and now that too. Damn that's beyond unreasonable.
Cults require delusions.
Old 11-28-2019, 11:27 AM
Edministrator
Steve Carlton's Avatar
Oops. I thought this was a thread about Van Halen.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 11-28-2019, 11:46 AM
Cars & Coffee Killer
legion's Avatar
Well, Van Halen is the name of the van...
5 liters of VVT fury now
-Chris
Old 11-28-2019, 12:05 PM
brainz01's Avatar
I'm glad I'm not the only one that saw Van Halen every time this thread popped up. Well done.
Old 11-28-2019, 12:28 PM
Bland
unclebilly's Avatar
Have you looked on YouTube?
I’m sure the adjustment is under the hood and sticks up as mentioned above.
Old 11-29-2019, 05:32 AM
Mr. Merk's Avatar
Mounting it up higher level with your high beams would make it much better, assuming it is a "driving beam" and not a "flood."
It should be perfectly acceptable to wire it in with your highs assuming you're not running your highs against oncoming traffic. The law states you may have four beams active with the high beam switch.
Most newer cars have four beams on already, like my wife's 997 & 957. I installed a relay harness on my 2005 GMC to enable low beams on with my high beams.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 11-29-2019, 06:04 AM
Cars and Cappuccino
tdw28210's Avatar
You could always replace the van headlight with van hagar.
Naw, never mind. That wouldn't work.
I had to read that title twice too. I seen the word "Van" and the next letter an "h" and my brain just fills in the rest as "alen". LOL
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 11-29-2019, 06:23 AM
Just thinking out loud
mattdavis11's Avatar
Don't do that. The law is wrong. One day a brighted driver may nail you. I can not stand most headlights of today, so I chose not to drive at night.
91 FJ80
84 Ram Charger (now gone)
Old 11-29-2019, 06:56 AM
legion's Avatar
Originally Posted by DanielDudley View Post
Looks to me like the adjustment screw is located between the two bulbs in the assembly, a couple of inches behind the bulbs and is pointed up.
This was the hint that got me going.
I've got it sorted out. Why couldn't they put this in the manual? It's not like this is a vehicle commonly used by commercial operators who may need to adjust the headlights for specific loads.
I started by pulling a headlight:
I immediately noticed a star-shaped bolt facing upright. This was not visible with the headlight installed but it must be the adjustment mechanism. To be fair, the last time I adjusted headlights was on a sealed-beam unit from the 80's that used set screws. I also noticed some wear on the star-shaped bolt, so the headlights have previously been adjusted (I bought the van used).
I reinstalled the headlight and noticed that the star-shaped bolt aligned with the hole in the frame:
After that was sorted out, I just turned on the headlights against the garage door and brought them up a couple of inches using a 1/4 socket. I'll try them out around town and adjust accordingly.
-Chris
Old 11-29-2019, 11:12 AM
Outstanding!
Old 11-29-2019, 11:18 AM
FUSHIGI
Perhaps they lowered them after having issues when frequently hauling loads or pulling heavy tongued trailers?
edit: If so, maybe change the trans fluid soon.
Old 11-29-2019, 12:53 PM
legion's Avatar
Trans fluid looks new to me. It wouldn't surprise me if it was changed before sale. Rental companies buy these vans, run them for one year, then sell them. It seems to me it gone through pretty thoroughly before sale.
-Chris
Old 11-29-2019, 02:36 PM
