Cooling an attic.........
The best thing you can do is have a continuous ridge vent installed along the peak of the roof. That will give you continuous hot air venting without having to install a fan or other type of powered vent. I had that done several years ago when I had my home re-roofed and it made a lot of positive difference!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Retired, finally
Thanks, though.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
We switched to a ridge vent on the roof after a hail storm destroyed the original roof. The builder had put in electric powered fan motors that had a temp sensor and they kicked on at some preset temp. After several years they start to make a lot of noise, and I had to replace one. I can tell you standing on a ladder in the attic to get up 15 feet to the motor, and take it out from underneath is something I would never do again.
The ridge vents are nice.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Ridge vent...........
A roofer could install a new ridge vent over your existing roof since shingles overlap from bottom to top. Probably would not be too expensive. I would at least call a roofer and ask!
Retired, finally
Good to know. Thanks!
Old dog....new tricks..... |
I'm not saying a ridge vent isn't a good idea, but that the whole venting process usually includes more than one aspect for it to all come together. When we re-roofed my house in metal earlier this year, we decided against a ridge vent, and just stay with the two existing gable vents and passive venting. They are oriented north-south so that should work the best for our prevailing wind directions here. Earlier in the thread I mentioned the prospect of adding a thermostatically controlled fan to push hot air out one end and that is something I'm probably going to try. I have a recording thermometer on order to help me with stats.
You do not have permissi
The ridge vent vents the air inside the attic space. -Heat travels to the ridge. -Outside winds help pull air out. It cools the underside of the roof (rafters/sheeting/shingles) with airflow. But it doesn't work without an incoming source of air, lower down, where it is cooler.
Meanwhile other things are still happening. |
That's exactly what I tell my clients and never forget to double up on the cost of the engineering. how the hell do you think I pay for my "Porch" parts?
![]() To that point....I received my recording thermometer with three sensors and have two sensors outside and one in the attic. Guess which one is in the attic? ![]()
75deg in the attic space in Florida?
What kinda shingles you got? Mexican clay tiles coated with titanium white?
BTW...if you are feeling a bit too hot....it is SNOWING in Michigan today.
Yup. And we have been breaking records for heat on top of the usual Florida "God-awful" heat we get. I know it's also happening elsewhere so don't mean to sound like we're special or anything....lol....
I have a 2 car garage with a flat roof and peel and stick that we replaced the tar and gravel with about 10 years ago. I just bought some Black Jack silicon roof paint to apply to that to get the reflective thing going there. It is not climate controlled (yet) so hoping this will help for that structure. Quote:
Looking at the image I uploaded, the top reading is inside my home where the base unit sits. #1 is outside front patio, #2 is attic, and #3 is outside back patio. Note the 10 degree higher temp delta. And that's under cloudy skies! ![]() Quote:
Not too bad here yet - but it's coming.....
Every time I see the title of this thread I wonder why anyone want to try to store light. Just flip the switch and take the light with you.
