Socket case on last legs -what to do for replacement?
My google-fu is weak, hopefully theres a cheap solution ive overlooked.
Got a cheap all in one socket set 25 years ago and the case is coming apart. I want something like it, organized and portable. Wouldnt mind a bit more room. I dont want a coffee can of sockets and bits. Thing is great except that its coming apart. Ideas? ![]() ![]() Box hardware stores have stuff but theyre full of tools already, |
AutoBahned
can you replace just the clear plastic 'window'?
do you like the way the case is laid out? do you really use it or just open the toolbox drawer, then open the case and grab what you need finally... I have seen people trying to create blow molded plastic cases for their socket sets - I swear that is true! |
I had one from Black and Decker and the hinge part broke off. It was just a thin strip of plastic anyway - you know the kind.
Called up Black and Decker and they mailed me a replacement.
Old dog....new tricks..... |
I've got something very similar without the plastic window in it.
If I were fixing this at home, I'd use one of my wife's old cutting mats that she uses when cutting material. It's thin enough that you could cut a piece that would fit inside the lid and cover the whole lid. Put some silicon caulk on it to hold it in place, I think it would stick. Does your wife sew?
Scott '78 SC mit Sportomatic - Sold |
Ayo Irpin, Ukraine!
If the case and hinge mechanism is ok and only the clear
Sheet that is failing, find a good hobby or art supply store and buy a sheet of clear styrene. Remove old and epoxy new. If the hinge and/or latch mech is toast,,,,, Time for a new set of tools. Donate those and buy a premium set that should come with a case.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
Preferred pronoun:Maestro
Have one printed?
_
When in doubt, use overwhelming force. |
How about a conventional tool box ? You said you wouldn't mind more space . There are plenty of socket organizers that could be used in a good ole hand carry tool box .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Doesn't have to be clear. Could be Aluminum or whatever you can score.
can the existing box be repaired or reinforced?
poof! gone |
You can buy bit holders and socket holders and move all the tools into a tool box.
https://www.zoro.com/eazypower-block-o-bit-case-empty-88289/i/G0565159/?gclid=CjwKCAjw5vz2BRAtEiwAbcVIL6ygQcVY7Xb-tHypXt_aEuDztQywW6l0a5pPzUUllYR1XKArwbWUdBoCUOcQAv D_BwE |
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Go old school. Buy some wood and use a router to make one complete with slots for everything. THen engrave the slots with the sizes/names and inlay with something so it stands out.
Platinum Member
This is the by far best organizer I have used over the years. Wish I bought more when they were on sale for $10:
https://www.homedepot.com/p/DEWALT-10-Compartment-Deep-Pro-Small-Parts-Organizer-DWST14825/203367153 You will have to mod it a little for the ratchet, everything else should fit.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Sorry i should have said what was wrong: one clasp is gone, the other is real thin, the hinges are on their last legs. Injection molded plastic. I guess i could weld a metal frame for the holders... hinge, etc. seems like a lot of work though.
These are my small travel sockets for stuff away from garage. Ive got tool boxes but little things like drivers will get lost. I hate pawing through a bag of sockets. Theres a ton of little pieces in there and its great to have all the sizes in order. Its pretty handy. Im a super 3d printer skeptic but this might be a reasonable use for one. I couldn't care less about the window. Wish i could just buy another one, lame injection molded thing lasted a good long time. Theres lots of bad solutions for this. Prolly theres something available deep on ali baba. I know... ill have my sons look. |
poof! gone |
Unregistered
Any info on make/modelbrand?
Maybe somewheres on the great wide webs there's an identical one fer sale that isn't all busticated Worth a shot. |
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
This may sound stupid or desperate.
But you can just cut the bottom tray out and glue it into another case that is about the same thickness, or find a thin Pelican case. https://www.cdw.com/product/Pelican-HardBack-Case-1070CC-with-Liner-notebook-carrying-case/3905083?cm_cat=google&cm_ite=3905083&cm_pla=NA-NA-Pelican_LC&cm_ven=acquirgy&ef_id=Cj0KCQjwiYL3BRDVARIsAF9E4GdATjYlOjpHPvk1vq-7GYMiepQLneYUnQ-nKjfnNA3fo24GmSaXn_0aAu2TEALw_wcB:G:s&gclid=Cj0KCQjwiYL3BRDVARIsAF9E4GdATjYlOjpHPvk1vq-7GYMiepQLneYUnQ-nKjfnNA3fo24GmSaXn_0aAu2TEALw_wcB&s_kwcid=AL!4223!3!359115308308!!!g!305181497892! |
Almost Banned Once
It really depends on how much you want to spend.
"Sortimo" is a German company and they make great boxes but they are $$$. However you'd only buy it once and fill it any way you like. (Search Google for "Sortimo". You can buy from their US online store) For socket storage I like these.
- Peter |
The Stick
I use socket rails in my regular roll around tool box.
Richard aka "The Stick" 06 Cayenne S Titanium Edition |
