What type of engine did this piston come from?
At a car show a month ago I won a trophy for 2nd place with my 911.
I was just curious, what did this come out of. It is obvious it is a well used piston.
In the center of the piston is stamped a 6 or 9, but unless it is from a HUGE 10 cylinder engine I suspect it is a 6. The other marking looks like it is an H.
You can see it is big piston, just fraction under 3 & 7/8th inch. If it matters I can use my calipers on it if they go that big and get a more accurate size.
I feel certain it is not a Porsche piston, and I honestly don't really care much, but I was just curious if the brain trust had a idea as to what it likely is from. Ford, Chevy, Mopar, or some industrial engine. I suspect it is the trash from some local engine re-builder.
I do know my wife is not real happy with it in the house as another thing to dust, so I suspect it will go to my garage to be on display for a while, and then to the attic or back to the car show folks as a donation to the next car show. I have an attic of trophies from Autocrosses and not many car show trophies.
Usually a Red Cabriolet or some flashy Turbo with a big wing and wheels win the popular voting. This was not a judged car show, just the people in attendance voting for their favorite of each category. With almost 300 cars there it was a lot to look at.
I enjoyed looking at the other cars as much as talking to people about mine. It was a fun day.
Old 10-02-2020, 07:59 AM
Laneco's Avatar
I didn't sleep in a Motel 6 last night...but that piston reminds me of small block chevy flat top pistons that have four cutouts for the valve relief - this this one courtesy summit racing (obviously this one is aftermarket).
angela
Hello
Old 10-02-2020, 08:14 AM
Unregistered
sammyg2's Avatar
It's machined with reliefs for 4 valve per cyl
Old 10-02-2020, 08:53 AM
4 valve per or the piston can just be installed either way with the same reliefs?
If it's 2 valve per, then I vote for Small Block Chevy.
Old 10-02-2020, 09:02 AM
angela
Wow, learn something new every day. Being only a two valve motor, what advantage would there be in providing four valve relief pockets?
There can't be many four valve motors with a four inch bore. Interesting stuff...
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 10-02-2020, 09:09 AM
I was guessing small block Chevy mostly because there are so many of them due to price. I have never seen a Chevy hot rod with a Ford engine in it. I bet more 32 Ford hot rods have Chevy engines than Ford engines.
Old 10-02-2020, 09:28 AM
Still Doin Time
asphaltgambler's Avatar
Yes ^^^^based on the picture looks like a true flat-top cast which would be early higher compression or replacement aftermarket
Old 10-02-2020, 11:21 AM
So if the average 454 has a 4.250 inch bore is this from a 350?
Old 10-02-2020, 11:28 AM
Arizona_928's Avatar
928...
dolor et pavor
Copyright
Old 10-02-2020, 11:29 AM
350 has a 4 inch bore.
Old 10-02-2020, 12:11 PM
Still Doin Time
more likely a 305...……..
Old 10-02-2020, 12:19 PM
Maybe some kind of Ls
Tony
Old 10-02-2020, 12:20 PM
Unregistered
sammyg2's Avatar
Turns out they do make chebby small block pistons with 4 valve reliefs, for peoples not smart enuff to build engines the right way.
BTW if its from a SMC and has a 3.743 bore, it's prolly a 305 or 262
Old 10-02-2020, 01:04 PM
fastfredracing's Avatar
Chevrolet 292 inline 6 ? Thats my guess . The rod looks different than a small block
No left turn un stoned
Old 10-02-2020, 02:08 PM
It will work on both sides of the motor, there is a front and rear .
Old 10-02-2020, 02:10 PM
Got a set of 350 chevy pistons. Here's one.
206 637 4071
Old 10-02-2020, 02:15 PM
It does make sense to make a piston that just one part will work on either side of a small block. Just one part to make and package and it works in any cylinder of the engine. No wonder the SBC is so cheap.
Of course if ya wanna, just "while yer in there", just change some parts out and spend as much as you can afford to for more HP.
Old 10-02-2020, 02:20 PM
wdfifteen's Avatar
I guess they don’t offset the wrist pin bore on an SBC.
Old 10-02-2020, 06:08 PM
The do offset about 1/8"ish.
Pic shows caliper and gap on the long side after measuring the shorter side. There's an arrow with "front" on mine, so on one side the arrow is on top and the other side it's on the bottom. Some have a notch on the edge that faces front.
206 637 4071
Old 10-02-2020, 07:08 PM
The piston in the OP has an odd shape to the casting below the wrist pin. Never seen that in a small block Chevy.
Old 10-02-2020, 08:14 PM
