Again, very few of today's refineries make asphalt as a byproduct or residue. Most convert it to fuel products. Quote:
http://forums.pelicanparts.com/uploa...1604605188.png https://www.eia.gov/todayinenergy/detail.php?id=9731 |
It's easy to tell if a refinery has coking capability.
The coke drum superstructures are some of the tallest and most obvious characteristics. The number of drums determines the process capacity. (4 drums): http://forums.pelicanparts.com/uploa...1604605516.jpg (6 drums) http://forums.pelicanparts.com/uploa...1604605540.jpg http://forums.pelicanparts.com/uploa...1604605576.jpg |
Where is the Asphalt coming from these days?
When I was working in India, 30+ years ago, they had "cold" stored residual oil which was basically just asphalt. You could walk across the open storage tanks. As a side note, one power station had a bunch of #2 (basically diesel) fuel oil peaking gas turbines. I cam in because they tested a unit and could not get it to full load. The pressure was very high and the relief valve on the fuel system was recircuiting more than half the fuel. Turned out, someone had refilled the #2 fuel oil tanks with #6 fuel oil. The viscosity of the #6 was causing the problems. |
renewable fuels like cooking or other used oil to diesel is limited, but not a pipe dream
do you know what type of renewable fuel they are claiming to convert to? |
little over break-even. Valero has a small asphalt plant in Wilmington, Ca, it's one of two local asphalt plants still operating that I am aware of. Note that we're talking the liquid material, not a pavement plant. http://forums.pelicanparts.com/uploa...1604607793.jpg Used to be they'd tear up an old road and dump the material and replace it all will new. Nowadays, they recover the old pavement and grind it up and mix it with a little bit of new asphalt, and recycle. that requires less asphalt than it used to. Petroleum coke is almost always sold at a loss, around $175/ton which barely covers the handling. but it is a true waste product. The money is made converting the tar into higher value fuels. Sulfur is also considered a byproduct of refining, but it can be a money-maker. Lots and lots of products are made with sulfur. Especially if the refinery has molten sulfur handling capability. http://forums.pelicanparts.com/uploa...1604607625.jpg http://forums.pelicanparts.com/uploa...1604607662.jpg |
They are converting to renewable fuels to participate in the Low Carbon Fuel Standard, which is a giant California mandated ponzi scheme. It is intended to make the cost of fuel VERY high, to benefit the environment, as only the rich will be able to drive.
I expect to see black market fuel stations popping up. Vans outfitted with 2000 gallon tanks to "buy" cheap black market fuel from AZ and Nevada and drive it over. |
I was first car in line waiting for a train to go through the metro area. I watched 90 or so tanker cars all labeled "Molten Sulfur" and thinking dang I sure they don't have an accident as they moved along. Scary stuff.
Anyone that has ever driven in Texas has seen the Bucky's gas stations. They are HUGE!. I bet they have close to 100 pumps, 6 or 7 restaurants, and the mall like central area. The bathrooms look like something from an football stadium in size. People are pumping gas like crazy and driving on the way.
I just wonder how even one of those stations can ever change to any other form of fuel. It would take a large power plant to make enough electricity to charge 100 or more cars at once. Then add in the tons of 18 wheel trucks. Just mind boggling. |
Marathon petroleum is also talking about converting it's shut-down Martinez ca refinery to renewable fuels, but there just isn't enough feed stocks available to keep these plants running at a rate that will generate enough income to pay for the operation. Quote:
Now they plan to make as much fuel in a year as they used to make in a day and a half?? Won't cover the property tax. They can fight over used french fry oil, they can fight over soy bean oil, they can fight over a few hundred bbls of algae a day, but the only way they can stay in operation is if the gubmint gives them truck-loads of $$$$ to operate at a loss. That is in addition to the gubmint mandating the use of renewable diesel in the state at a cost of at least $20/bbl. I'm betting that's what they are counting on. Now THAT will be an oil company subsidy. Bigtime. And who pays for that? the consumer. **** is gonna get 'spensive. DISCLOSURE: I spent the last couple a years trying to figure out how to make this work. |
The trucks on the highway that scare me (and I'm fearless) contain chlorine, sulfuric acid, or the worst, hydrofluric acid. HF be bad. https://emergency.cdc.gov/agent/hydrofluoricacid/basics/facts.asp |
the guys here doing cooking oil to diesel are doing well - it is a simple process (I was able to convince a neighbor NOT to do it in his backyard)
they have 3 or 4 service stations that sell it |
Note this is from an extremist activist group so is likely exaggerated for effect.
But I've worked in the HF alky plant at both of these refineries in my career and don't want to go near either of them again. Quote:
https://thumbs.worthpoint.com/zoom/i...b97dd8d334.jpg |
The methanol is the dangerous part, big toxic. But to do it on an industrial scale, there just isn't used cooking out on the planet. Not to mention it cost about $10/gallon new in bulk ..... |
What you GET is a RIN, if you can show that the fuel was actually used in a vehicle. And, you can get a LCFS credit if you show that it is used in a vehicle in California. Natural Gas is about $3/MMBTU. If you get the RINs for 1 MMBTU, the value goes to about $17/MMBTU for Renewable Natural Gas. The LCFS score on our landfill gas was not very high, but if we can broker the sale to a CNG station in California, it is worth another $12-15/MMBTU. These RINS and LCFS credits are required to be purchased by the oil industry, which raises the price of delivered fuel. You're Welcome. |
If gas does get expensive in California drivers may have to resort to sensibly sized cars, in place of the unecessarily large commercial vehicles many currently drive.
1). Why aren't trailers self-propelled using regenerative electric? Start-stop. Huge masses. Over and over. That is where the major loading occurs, parts wear out, and fuel consumption is being used for the local delivery semis dealing with city traffic congestion. Local service designs should be the opposite of long haul designs. 2). The trailer connection-pins are only about 5" iirc for taking the whole load shift forward and aft. The entire weight of the trailer plate sits on the tractor's 5th wheel and constantly rotates with every turn of the truck. That is a major friction wear point, Nobody in the shop was instructed through practice or policy to scrape off crusty dry grease and replace with fresh grease, and hardly anyone did it. There must be a better system to making this connection without losing grease off the sides of the road. 3). Overland tractor-trailers are still being built as square boxes despite spending much of their time at 60-80mph highway speeds. Simple alterations could improve fuel efficiency 10-50%. There are side skirts and a few have "trailer-tails" but those are weak band-aids. |
Sure thing ...
https://www.rigzone.com/news/energy_sec_warns_oil_of_kodak_risk-29-apr-2021-165293-article/ Jennifer Granholm, the U.S. Secretary of Energy, has urged oil companies to diversify and not become the Kodak or Blockbuster of energy in a new video interview published by Politico. “The bottom line is, you have got to move and you can’t hang on and be … the Kodak or … the Blockbuster video of the energy world,” Granholm told Politico in the interview, which was published on Monday. |
| All times are GMT -8. The time now is 01:19 PM. |
