Iridium spark plugs - Change a little early or not?
2014 Hyundai Sonata 2.4L naturally aspirated engine.
95k miles on clock but plug change interval is 105k. If all else is ok, will I gain anything by changing early? $16 each retail price at Advance Auto so it is a wee bit of coin for her plus my beer money to change out (sister in law-way hawt) |
It will save you from having to do it in 8 months. Sure cannot hurt. I think its always nice to catch them before they start causing missfires, and early coil failure .
We need pictures to be sure though . |
As fred said, it wont hurt. The main benefit to iridium plugs is longevity.
One thing you may want to research is using a different type of plug with a slightly larger gap. I had a Ranger with the Duratec engine.. used iridium plugs rom the factory. $20 per plug. I ended up trying a copper core and gapped it a bit larger. There was a noticeable difference in pickup and no change in MPG. Might be something to look into. Only downside is having to change them every 10K miles. |
I did that and it noticeably smoothed out and owner agreed. I did clean off the MAF as well so I can't quite take that to the bank as a certainty but I am now aware. |
http://forums.pelicanparts.com/uploa...1611781301.jpg |
They last a really long time.
Prolly won't notice a bit of difference. Iridium plugs I mean, Not women. |
Changed them out on my Rav4 at 97000 and they still gapped the same as the new. Same thing on my 2010 Ford Fusion. But it can't hurt.
If she's a Browns fan... charge her double! :D |
I went too long on my Taurus X and you could definitely tell. Amazes me the computer never registered a misfire. The car would chug like the transmission was searching for a gear. I changed plugs and BAM! problem solved. You could see one cylinder was misfiring.
What's it take to make this select group? I've got an engine drop/ trans swap coming up on the 911. |
Sorry Bobby, but no. She will just have to come back in 10,000 miles won't she? Her airbag lights are on too
Her brother and my sister are married and live near Charlotte. Airbag lights. +0.85 Rear bumper +0.973 Footnote: Greater Metropolitan Akron, Ohio standards. ;) |
Hey Patrick! We need to put together some kind of package deal here. I get him for 2 days. You come up here and we get my projects done. Then we all go to your place and work on projects for 2 days.
As to failing coil packs, BMW and VW's are the notorious ones but I don't see all types of cars. I do know cars that have leaking valve cover gaskets and allow the coil pack to swim in oil (e.g., Subaru/Focus) will promote failure. |
| All times are GMT -8. The time now is 01:01 PM. |
