-   -   What does this light mean? long hood (http://forums.pelicanparts.com/showthread.php?t=1089877)
RNajarian 04-02-2021 07:02 PM
Originally Posted by TimT (Post 11282949)
And even that link /picture doesn't match the picture the OP provided..
Who has eve seen a flickering brake warning light
We don’t have all the information. What year vehicle are we even I’m not near my 911 or owners manual now. I know the solid red light under the B light indicates the handbrake is on.
My brake fluid has never gone low so I am not sure about this but PERHAPS the flickering brake warning light indicates low brake fluid level. . . or a ground issue.
look 171 04-02-2021 07:27 PM
Webb, its a 72. Oh yeah its been messed with. There's no wipers, no wiper motor and its basically stripped for weight reduction. The toggle switch is my fuel pump switch. A big Carter fuel pump mounted under the hood next to a just about two gallon oil tank.
look 171 04-02-2021 07:29 PM
Originally Posted by RNajarian (Post 11282926)
Not sure if you are being facetious with this comment.
I think his gauge is different than the one in your ‘71 owners manual.
If you look at his photo the top light has a B under it (handbrake/fluid) and the bottom light has a G (Generator).
This, but Tim's photo of his book confuses me. E brake light shouldn't flicker or dim out.
RWebb 04-02-2021 07:57 PM
my '73.5 looks like yours
your brake light 'reads' the parking brake AND the brake fluid level I think
you may have to trace the wires, but turn the LF tire outward, crawl in with a rag & light and see if there is a wire going to the brake reservoir on the m/c
fintstone 04-02-2021 08:20 PM
Originally Posted by TimT (Post 11282887)
No, that is incorrect
I'm guessing the OP is asking about the illuminated large red light..
Which is the Alternator warning light,
The bottom light in that gauge is the handbrake.
Apologies, my printer/scanner recently went kaput and I haven't replaced it, so pics
From a '71T manual which came with the S gauge package..
http://forums.pelicanparts.com/uploa...1617408759.jpg
http://forums.pelicanparts.com/uploa...1617408956.jpg
That is not the gauge he has in his photo. The red light is clearly marked with the brake symbol and the bottom with the Gen (alternator symbol). I would guess his gauge is probably out of a '73 2.7
maxnine11 04-02-2021 09:06 PM
I'd be concerned about the zero oil pressure at 1425 rpm.
maxnine11 04-02-2021 09:14 PM
http://forums.pelicanparts.com/uploa...1617423219.jpg
look 171 04-02-2021 09:46 PM
Just checked, no light on all gauges. Tach is the only gauge that works. When I turn the keys, the red and green light lid up on the oil gauge. So there's power going to it. The little blue light next to 2000 rpm on the tach only lights up when key is on "Accessory" and goes off then I turn to on. I just discovered this blue light 5 min ago. Checked fuses, all are good. But will test with test light tomorrow. Jiggled wires behind and under dash and fuse box, all are good and connected. The fuel gauge doesn't work, or not connected. Need to pull it during daylight. I think there's power going to the gauges, but somehow it isn't lighting up or working. No clock btw.
look 171 04-02-2021 10:08 PM
Correction. The blue light next to the 2000 rpm mark only turns on when the light switch is pulled out half way to turn on side markers lights. So, I am getting power but no lights.http://forums.pelicanparts.com/uploa...1617426471.JPG
look 171 04-02-2021 10:12 PM
Here are couple more pics. If you guys see anything unusual, plesae let me known. Sorry for not putting this type of question over in Tech. I haven't post over there in many years so I didn't want to get chased out of there.
Looks like the speedo isn't connected at all.
http://forums.pelicanparts.com/uploa...1617426609.JPG
RNajarian 04-03-2021 06:55 AM
Unfortunately I do not have access to my car right now to check out my ‘75 owner’s manual, but look at the photo from this post.
http://forums.pelicanparts.com/porsche-911-technical-forum/1068665-1974-temp-specs.html
On the right of this photo you can see the manual is talking about the B light and you can see it says in the cut off photo it references a light that flashes.
Does anyone have this in their owner’s manual?
http://forums.pelicanparts.com/uploa...1617458116.jpg
Starless 04-03-2021 07:22 AM
I was just about to post that. Strange nobody brought it up.
Walter_Middie 04-03-2021 12:03 PM
The link I posted with the picture of the master cylinder with a brake light warning switch attached to it was from an early long hood - not from my MY 1975.
Take a look at your master cylinder and see if it has this switch. If so, disconnect the wire going to it and see if your light goes out.
rusnak 04-03-2021 02:38 PM
when you say "no lights" do you mean the background illumination? There is a common wire for the illumination. If it shorts to ground, then you'll burn the entire wire and lose all background illumination in one go.
rusnak 04-03-2021 02:41 PM
oh my. Yes, a lot is unusual. As for the wiring, you need a wiring diagram matching whichever year your gauges are "compatible" with. In other words, determine which MY you are going for, and you may need to graft onto the harness.
look 171 04-03-2021 02:41 PM
Yep. No background illumination. This is for all the gauges, no lights. What's the blue light next to the 2000 mark on the tach? Will tear into it later this evening and search for ground wire.
look 171 04-03-2021 02:42 PM
Thanks, will look.
rusnak 04-03-2021 02:43 PM
The blue light indicate high beam headlights are on.
For what it's worth, the original guage illumination wire was blue/ black. It was sort of daisy-chained from one bulb to the next.
look 171 04-03-2021 02:53 PM
Cool. It would have taken me 3 hours with a test light to find that ground wire. I should just run another solid grounding wire and daisy chain them and be donw with it?
The blue light, high beam light comes on with a pull of the head light switch half way or the first click. There's some funking siht going on behind there I must sort out.
rusnak 04-03-2021 02:55 PM
No, they ground against the guage. The single wire is positive.
