Beretta Silver Snipe
Any owners here?
Is it possible to switch the trigger from the bottom barrel firing first to the top?
Old 06-30-2021, 05:14 PM
MRM MRM is offline
Silver Snipe is a name Beretta used on a few different guns. Not all of them had trigger selectors. What year or era is yours? The Silver Snipe SST model had a single selective trigger with extractors. I don’t believe any had ejectors. If you look at the safety do you see something extra that might be a trigger selector? It should be in the center of the safety button.
If there isn’t a trigger selector you should be able to reset the other barrel by firing the first barrel (on a snap cap) and then flicking the safety on, then off. Usually, this will reset to the unfired barrel.
MRM 1994 Carrera
Old 06-30-2021, 06:21 PM
(the shotguns)
berettafan's Avatar
If it's not on the safety then i don't believe you have a selectable trigger (SST).
Early models of the Silver Snipe didn't have this.
You could call Cole in Fla and ask about making it a double trigger gun if you are attached to it.
Old 06-30-2021, 07:34 PM
Thanks guys,
I have tried the safety but it only appears to be a safety. I will look into this a little more.
Old 07-01-2021, 02:43 PM
(the shotguns)
berettafan's Avatar
The selector on Beretta safeties is pretty obvious. You'd know it if you had one.
Old 07-01-2021, 04:08 PM
