Missing some teeth
Biking yesterday with my Vilano belt-drive 8 speed.
I had gone about 8 miles out when the belt drive started a small hesitation when pedaling. Looked at it closely and saw a few teeth missing.
Turned around and headed back...the further I went, the more it was skipping.
By the 8th mile back...it was hardly engaging at all.
Called Vilano and they are sending out two new belts asap. The second one will be a spare.
See the pic for how many teeth I lost.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-26-2021, 02:27 PM
Control Group
Tobra's Avatar
How old was that thing?
Old 07-26-2021, 02:46 PM
About two years...but a lot of miles.
I think I might have had the tension set too high. If it was too low..it would have skipped earlier.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-26-2021, 02:49 PM
Zeke's Avatar
Wouldn't too high a tension be felt in resistance? IDK, I don't have a fancy bike. We used to run drive belts on enduro karts where the one speed clutch was on the axle. Not as much killer heat on an axle clutch. Ran them tight, but not banjo string tight. Tightness builds heat as well.
Then they deteriorate. I bet the sun had something to do with yours. Or, what do they call it, ozone and something called "double bonders?"
Old 07-26-2021, 03:24 PM
Looking closely at the belt...I can see how one missing tooth leads to the next one being gone also. Looks like they are glued on with a layer of plastic/rubber applied afterwards.
Maybe tension was too low...I don't know. When I put the new belt on...I might take it to my local bike shop to verify the tension.
The belts are $50 each...I don't want to mess up with the wrong tension.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-26-2021, 03:33 PM
Preferred pronoun:Maestro
Norm K's Avatar
By any chance, does the belt manufacturer have a plant in Arkansas?
_
When in doubt, use overwhelming force.
Old 07-26-2021, 03:34 PM
_
It's a Gates belt. The printing on it says "CDrive TW Belt 8M1248"
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-26-2021, 03:36 PM
I took another pic. As you can see...I can easily peel back the next tooth in line.
If I had gone another mile...they would have all been missing.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-26-2021, 03:55 PM
wdfifteen's Avatar
It’s sounds like you’ve had one hell of an interesting life Milt. And somehow you ended up here. I’m honored.
Old 07-26-2021, 04:29 PM
Location: behind the redwood curtain, (humboldt county) california
I thought the title might suggest a girlfriend.....
_
On more sober reflection, i realize i'm a bit apprehensive about my stepson's recent purchase of a 924S, (with a 944 engine/ timing belt & Balance shafts drive belts) - and no exprience with WET porsches.
Cheers,
chris
Old 07-26-2021, 04:33 PM
Watched a few YouTube videos last night on setting the tension.
A couple vids recommended using the Gates app on a smartphone. You hold the phone near the belt and strum it. The frequency tells the app when the tension is correct.
Most of the videos remarked that it is better to have too little tension than too much tension.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-27-2021, 11:41 AM
Or if you're a real badass, you'll use a tuning fork!
That's crazy, app that determines belt tension based on frequency. Just don't hum while you're checking the belt!
Old 07-27-2021, 12:30 PM
I was thinking "that sounds like the kind of thing that you'd carry as a spare."
Old 07-27-2021, 12:33 PM
I thought this video was excellent for anyone leery of buying a belt-drive bike.
Everything he says...I agree with.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-27-2021, 12:39 PM
Hah!....I ordered two just for that reason. (I won't carry the spare...but it will avoid the week shipping)
Not easy to change the belt...on the road.
The bike frame...like mine...needs to have a 'breakaway point' to get the belt on or off. (it's a bolted joint to allow pass-thru)
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-27-2021, 12:41 PM
You do not have permissi
john70t's Avatar
One internal metal sprag (if that is the right word) per gear welded to the cables would have made that drive bulletproof.
They want to sell belts.
Old 07-27-2021, 01:07 PM
vash's Avatar
_
hahhaha..i'm hoping this was a joke, because it was good!!
you're riffing off the old joke, "whats the best pickup line in AK"?
"nice tooth!".
right? if i'm wrong..sorry. especially if youre down to a single tooth
poof! gone
Old 07-27-2021, 01:14 PM
This video is very interesting....and shows how complicated the hub drive is on a belt-bike.
The same hub that is on mine....but the cog on mine is driven by a belt...instead of a chain.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-27-2021, 01:19 PM
Model Citizen
herr_oberst's Avatar
I understand that the toothbrush was invented in Arkansas...
Old 07-27-2021, 02:40 PM
^^^ If it wasn't...it would be called a teethbrush.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 07-27-2021, 02:43 PM
