I see you
using an internal hard drive externally
I pulled a 1TB hard drive out of my old desk top and am wondering if I can use it as external HD. It says SATA 64 MB cache on the label
Do I need anything more than cable?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 08-19-2021 at 07:51 AM.. |
You can look up hard drive enclosures. They are common. It will be a plastic box, and a power supply and the connectors. You will need to get cables as well most likely.
That way you can just turn it on when you need it. Be 100% is is a USB 3.0 or 3.1 if you have the 3.1 connector on your computer. Do NOT even buy a USB 2.0 enclosure. That is so slow as to be useless. The are cheap. And it will let you easily turn it off, and put it in the closet or someplace out of the way when you don't need it.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I see you
I don't know one USB from another.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Exactly what Glen said. You buy an enclosure, mount the HDD and then plug in the power and communications cable (likely USB) and you're good to go.
You'll need to know the details of your drive to ensure that you buy something that fits, but that's not likely to be a big deal. https://www.amazon.com/s?k=sata+enclosure
Brew Master
Something like this
https://www.amazon.com/Inateck-Docking-Station-Offline-Function/dp/B06XYL599P/ref=asc_df_B06XYL599P/?tag=hyprod-20&linkCode=df0&hvadid=241907595991&hvpos=&hvnetw=g&hvrand=2801693147628654193&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9015981&hvtargid=pla-401132470768&psc=1 Some folks call them a toaster. I searched external hard drive toaster. I suppose docking station makes more sense.
Nick |
Brew Master
If you go into your device manager it should tell you what your USB adapter is.
Nick |
I see you
Thanks guys!
Don't let him scare you. Remember, his PC is super powered. For the avg person, if you've only got USB 2, it works. It's slower than if the thing was inside your PC, but it works. But yes, if you've got USB 3, then definitely make sure that you take advantage of it.
My understanding is that the main difference is that USB 3 ports should be blue while USB 2 ports are usually white. ![]() When you get into other formats A vs B vs micro vs mini, etc... there are some other differences.
USB 3.0 typically has a blue edge on one side of the connectors. USB 2.0 is just balck and white.
USB 3.1 is a little tiny one with the same connector on both sides. It is common in cell phone charging cables. There is no upside down with 3.1, it works no matter what side is up. If you computer does not support it, stick to 3.0. You might have to look at the back of the computer if it is a desktop. A laptop is likely all 3.0 if it is not really old.
The difference is speed from 2.0 to 3.0 is HUGE.
2.0 is really slow and you will hate copying much at that speed. It is like an old dial up modem instead of broadband.
I see you
Blue they be.
Band.
I have quite a few docking stations sATA to usb(2 and 3) and they are great and rarely fussy. AND if you need more storage you have plenty of super cheap options in bare sATA drives.
1983 SC Coupe 2020 Macan Turbo 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Easy peasy....
Scott '78 SC mit Sportomatic - Sold |
I see you
Thats what I have except that it is WD Blue. Which case is that?
It's a Sabrent case.
I have a blue WD too. Just slide it out and plug in the other one. Simple.
I dont know how it works but my brother put an extra one in my computer. Semi external?
82 SC , 72 914 |
wtf!?!
Platinum Member
Damn Dell and their proprietary non-standard PS connection.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
