"At this point in time" especially being the qualifier for many of us (I'm 67). I did some stretches earlier and it seemed to help.
Old dog....new tricks..... |
I despise taking any kind of pills actually so shouldn't be a problem. In fact, I had some Prednisone left over from when I had Bronchitis last year. But posts like yours are important because at some point someone else will read this thread and learn from it, benefiting from your posts as well as all the others, regardless of my situation.
Mine is finally under control, Chiropractor stretching exercises, red laser bed(looks like a tanning bed) but where I got the most relief was a couple of lidocaine shots in the bum to block the nerve so I could do the above.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Mighty Meatlocker Turbo
Ken 1986 930 2016 R1200RS |
Just go and see the doctor. Self diagnosis are not always correct from my experience.
Well, even after starting the two prescribed meds, my leg was still in pain today.
So I decided to deploy some of my CBD arsenal. Took one of the Delta 8 Gummies and rubbed my leg where it was hurting with the salve. Pain was cut in half within' one hour. Now down to 25%. Huge game changer. After I deplete what I was prescribed for the meds, which should be by Tuesday, I will go solely with the CBD route, and see what happens. Thanks!
Quick update - leg pain almost gone and I can walk normally again vs. being a bit hobbled.
I've kept to the Prednisone 10mg. and Gabapentin 300mg. prescription my doctor recommended and feel they were very instrumental in the recovery. I have enough meds for one more day and then will be finished, providing the issue does not return, God forbid. I have no craving for these meds and will be very happy when done with them. I have not used any CBD products since Sunday - and even then it was just some balm on the lower part of my leg where I had some pain. The reason I stopped is I wanted to see how the prescribed meds were working on their own. Of course there's no knowing the exact degree the CBD products had on overall recovery, but I feel they did help on those two days when the pain was more prominent. The resiliency of the human body never ceases to amaze me.
Glad you're better. The key from here on out is moderation in exercise with proper stretching. You have to get your framework back in balance. Swimming is great. Just treading water is good enough.
Baz, 10mg Prednisone won't cause the horror story stuff mentioned by me and others; I was taking 4X that for months on end and 10mg dosage was well into my weaning-off period.
Still here
Alcohol works too, enough used.
Did I mention MRI ? |
![]() Quote:
![]() Yes, you did! Did you see my last post?
I tried that, couldn't even sit at the bar for more than 5 minutes before the pain was too much.
Still here
My Dr did x-rays on my back a few weeks back when I thought I had a bad case of sciatica.
The x-rays showed compressed fractures of two vertebrae. He set up an MRI in a couple weeks from now. I'll most likely have to have surgery. It gets real bad with walking or lifting.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Google Dr. Stuart McGill if you want to zero in on your issue and how to work around it.
15 years ago I ruptured a disc (even I could see what looked like a spill on the MRI) and had a microdiscectomy to remove the offending disc material off of my sciatic nerve root. Did it help, yes… maybe 60% better but I would tweak my back constantly doing the simplest of things. For the next 5 years I was very limited and my fitness level and quality of life went down hard. Not until I found McGill’s books about 5 years later did I begin to almost immediately improve. I joined a gym and slowly improved my core and back tensioning muscles so my spine stays tethered in a good position. Watch out for “stretching”, too, as the wrong ones can put your spine in a position that further raises intradisc pressure and can exacerbate your issue. No sit-ups or curls! Don’t get surgery for a disc issue. Studies suggest surgery /non surgery groups are just as unhappy as each other 1 or 2 years out. The key is to avoid the positions that inflame it for long enough that the inflammation goes down and you can strengthen your stabilizers.
