Math question: diameter from a portion?
Hi,
I have a small wooden part with a curve to it and I want to replicate it on the lathe by turning a complete circle so trying to figure out how to take the measure of the slice to get the whole. To make a simple comparison, if I had a slice from a pie and wanted to figure out the diameter of the pie from just the crust curve of one piece. Hopefully the brain trust can steer me “straight”. Thanks, Rutager
Rutager West 1977 911S Targa Chocolate Brown |
I think this calculator gets you what you need:
https://www.omnicalculator.com/math/sector-area
1982 911 Targa, 3.0L ROW with Webers |
Model Citizen
Like this?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
I was about to say "I love banana cream pi"...but am afraid of where that might go.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 03-14-2022 at 05:12 PM.. |
You can do it by math or get a large enough piece or craft paper and stick a pin to act as the center and rotate your piece around it and draw a line on the outside until you get a full circle. Then measure across the circle.
John |
Perfect- great explanation and easy to follow.
Thanks!
Mmmm... Cherry Pi
Happy Pi day
- Peter |
What about making a compass thats big enough to accomodate the wedge?
^^^ That's what she said.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
In this case, my piece doesn’t go to the center, but I bet I could run lines down each side and measure from the middle to get the empirical answer. Just tried it and apparently the diameter would be huge as the lines weren’t even close at two feet out! I may have to give up on the lathe idea. Here’s the project- I got a bunch of hand plane bodies and I wanted to make a custom wood infill for one. The originals were Rosewood or anodized aluminum, so I do have a piece to use as a pattern, just thought it would be easier to turn a section, but my lathe won’t turn a huge diameter inboard and I’ve never tried outboard turning.
Apparently Byron left his camera at my place! Sorry about the blurry picture.
Banned
this is an easily googable problem.
The Unsettler
Seems infinitely simpler to use one of the pieces to trace out a template then hand shape.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
- Peter |
My initial thought was that since it had several facets and a compound curve that I could get a “perfect” shape if I turned it and could also make several at once and even out of different woods by doing segments on my round blank.
Senior Member
Clever.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Takin' hard left turns
You could rough-cut the shape, then attach it to a long pivoting arm and pass it over a router.
Rutager,
If I follow your issue - why don't you cut a jig to match that diameter and just use a router with a follower bit and/or bearing? Edit - I didn't see Amail's comment which he posted after I had opened the tab a while ago.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
