Low Voltage Question
For the brain trust. Installed yard lights down stream from my transformer. Low voltage LED fixtures. Worked well, then my connection go wet and no go. Have pulled the wiring from the ground and was testing. Lights flicker. On touching the wire, it was hot, very hot to the touch. I thought there is little current running through so I am surprised at the heat. Transformer is rated for many more fixtures than I have on the line. Now have four plus the two in question
Will re-splice all connections and heat shrink them again. Thoughts on why the wire was hot?
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
I see you
Will a ground of some sort cause current to keep flowing and produce heat?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
It's a misconception that low voltage will not produce heat when wires are crossed. That is what is happening there. You have to go back over everything and find the short.
Can be tedious but with your simple system not bad. Just be thorough and you'll find the issue. Potential issues: transformer, cable, LED fixtures, LED bulbs, connections. I don't heat shrink my connections - I use wire nuts filled with dielectric grease.
Old dog....new tricks..... |
Thank you Baz. So, I have a cross connect positive/negative. I can fix that. I have tried wire nuts with the dielectric grease, but those did not work for an extended period. Its in an area around a fountain that has proven beyond troublesome.
Will just get out there and reconnect things.
Baz, one more question. It appears as though the two wires on the fixture have differing wire color. Assuming I keep like to like to be sure. Will it matter when I connect them to the main power wire coming from the transformer? Not sure how that wire is connected, which side to which pole.
yep, I'm on it. And for that advice, a little remake of Peter Green's Station Man, Pete Townsend playing
Thanks, brother. My fav. song off Kiln House. And PT is great!
Heh. I was making tantalum carbide in school with a vacuum furnace that ran at 6V. There was however about 2000 amps though going through those graphite heating elements. It was at least 1800C - the peephole in the door projected a nearly white light across the room.
The safety lesson was, besides the heat and the (related) importance of keeping the cooling water on, you can touch the conductors but for god's sake don't drop a wrench on them. You'll get blowed up. Electricity is strange...
'78SC, lots of other boring cars... |
Before the heat shrink use some dielectric grease. I suggest a brand callled super lube.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Was the entire cable hot or just the where the joint is? If it is the wire getting hot, is it rated for direct burial?
87 930, Last edited by 908/930; 06-03-2022 at 09:44 AM.. |
my first thought. heat in a circuit = short.
Couldn't see my mistake when I first pulled is apart. I now have the fee cable (2 wires) and the two low voltage fixtures with 2 wires a piece When the sun quits hitting the site (105 right now) I will carefully connect two of the fixture wires to one of the feed, heat shrink and electric tape wrap, then do the other 2 fixture wires to the feed. Repeat.
May even send a pic or two so the brain trust can tell me what I am doing wrong.
) and it seemed to work.
Couldn't see my mistake when I first pulled is apart. I now have the fee cable (2 wires) and the two low voltage fixtures with 2 wires a piece When the sun quits hitting the site (105 right now) I will carefully connect two of the fixture wires to one of the feed, heat shrink and electric tape wrap, then do the other 2 fixture wires to the feed. Repeat. All rated for direct burial.
Wire was hottest near the connections, but warm for a bit of a distance May even send a pic or two so the brain trust can tell me what I am doing wrong.
Any resistance in the line or joints will likely create heat, if you can, twist the wire tight and solder it, then wrap it to protect from moisture. how many Amps are each LED light and how many lights?
87 930, |
canna change law physics
P = I^2 * R If there is a short or really a ground, it will heat up the wire. If you have a wire smaller than the rating of the transformer, it could heat up to the point of fire.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Photos are always helpful.
Also, there is a way to troubleshoot where certain components can be eliminated as the problem. Start with transformer - measure output in volts. 12v? Good. Hook up cable and connect to known good light fixture. Comes on OK? Good. Now you know the transformer and cable are OK. One by one re-connect each fixture. Other than that - the problem might be associate with a deterioration of your components and/or connections due to weather and natural elements. Like I said earlier - it's very basic and should be straight forward to toubleshoot...
You do not have permissi
A five foot fountain of sparks with a small hole burning through the hood followed. I think it only takes 1/10th amp to stop the human heart. (and yet Tesla could repeatedly shoot lightning from his fingertips)
Meanwhile other things are still happening. |
