Recreational Mechanic
Nickshu's Avatar
Washer Fluid Problem - How do I dissolve Rain-X?
I have used the Orange Rain-X All-Season windshield washer fluid for years on all my cars and never had a problem until recently. I refilled my 2021 SuperDuty recently and must have gotten a bad batch with way too much Rain-X in it. I got a surprise while towing my trailer down the interstate...hit the washer and it was like I sprayed my windshield with silicone tire-shine. I was blinded....Had to stick my head out the window to see until I could pull over and spray-wipe-spray it off. Fortunately I had glass cleaner and paper towels in the trailer.
Once home I pumped out the reservoir w/ a Harbor Freight suction pump and then stuck a garden hose in it to flush it out...running several tanks worth through the sprayers until the tank was empty...refill and repeat. Then put plain old blue washer fluid in it.
Unfortunately I still have greasy washer fluid coming out. I have read Rain-X is silicone based. Any ideas on how to dissolve the Rain-X from the walls of the tank and hoses? Or should I replace the tank, pump and hoses with new ones?
What a massive PITA. Thanks for any advice you can give me.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 09-24-2022, 04:53 PM
Perhaps white vinegar?
Old 09-24-2022, 04:59 PM
I see you
flatbutt's Avatar
I think Rain X uses acetone in it's formula. You'll need that or something similar to remove it from the tank. If'n it was me I'd replace the tank.
edit: oh wait, just realized that it's not the Rain X treatment...sorry
Here is a link for the MSDS of their products:
. These will tell you what solvent is used in the product. If it's not an exotic you could use it to clean the tank.
https://www.rainx.com/heres-how/safety-data-sheets/
Check out the one for the windhield washer additive
Product Name Rain-X Washer Fluid Additive
Product Code 31037
Document SKU: RX11314, RX11806D
It looks like IPA is the solvent.
I'd still opt for a new tank but I'm lazy.
Old 09-24-2022, 05:00 PM
Nickshu's Avatar
Yeah I saw that online 50/50 water and white vinegar. May be worth a try. I'll say it again, what a PITA. I'll never use this stuff again.
Old 09-24-2022, 05:08 PM
What about rubbing alcohol? Would that cut it?
Or call the number on the washer container...they might help.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 09-24-2022, 05:13 PM
I see you
flatbutt's Avatar
That's what the MSDS listed as the solvent.
Old 09-24-2022, 05:15 PM
^^^ I didn't read your link until now...never knew rain-x had that many products.
A couple IPA's sounds like the solution.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 09-24-2022, 05:33 PM
FUSHIGI
Any chance someone put antifreeze (or ??) in the washer tank?
Cults require delusions.
Old 09-24-2022, 05:34 PM
I always use the Rain-X additive. Squirt a little in the tank with the water and I'm good to go.
Good luck with getting things clean.
Old 09-24-2022, 05:56 PM
Arizona_928's Avatar
Ethylene glycol isn't good to be dumped....
Alcohol is the go to for lowering freezing point.
dolor et pavor
Copyright
Old 09-24-2022, 06:02 PM
So isopropyl alcohol shouldn't leave any residues. Over conc. Shouldn't be an issue.
Acetone is harsh but is good in hdpe. If you have heavy residue and acetone doesn't touch it. I would do some dcm next. But it's a nasty solvent
dolor et pavor
Copyright
Old 09-24-2022, 06:05 PM
Nickshu's Avatar
No. I have owned the truck since new and do all my own maintenance.
Old 09-24-2022, 06:10 PM
rfuerst911sc's Avatar
I would give Rain X a call and tell them your story . They should be interested if they have/had a bad run of product . They also should be able to answer your clean up questions .
Old 09-25-2022, 10:39 AM
pwd72s's Avatar
Thanks for the heads up...really dunno why, but I've always grabbed the old 20-10 fluid brand.
Old 09-25-2022, 10:42 AM
Edministrator
Steve Carlton's Avatar
Agree. They might even pay for it. I had luck like that years ago for a girlfriend's situation.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 09-25-2022, 11:19 AM
Just flush it with acetone then plenty of di water and move on with life.
As they say in the hazmat cleanup world. The key to pollution is dilution.
dolor et pavor
Copyright
Old 09-25-2022, 12:13 PM
Nickshu's Avatar
Tried hot water several times and then 50/50 white vinegar and hot water. Still getting greasy sludge out of it. Have not tried acetone yet, will pick some up tomorrow. Don't really want to spray the truck w/ acetone so will need to flush it out well after directly from the pump. Wonder if acetone will destroy the pump.
Old 09-25-2022, 04:20 PM
pwd72s's Avatar
Acetone sure can eat rubber or plastic...
Old 09-25-2022, 04:48 PM
Acetic acid is not good with organics. I only use glacial at that.
Acetone is very stable with hdpe. Abs eh.
Your fluid tank is hdpe for sure. Pump is probably the same to be rated for ipa use. .... Disconnect the hose from the nozzle if you do acetone and collect the waste from the hose.
Try IPA first or methanol. Then if it doesn't clean it out go to acetone for the tank and see if the lines could be flushed...
Do you have a picture of the junk in the tank? It would be beneficial to know if you have an organic or aqueous...
Also I know on my 18' 6.7 ram, if you're not paying attention; the washer fluid and power steering fluid containers look very similar and are right next to each other.
dolor et pavor
Copyright
Old 09-25-2022, 04:58 PM
Depends on the plastic.
dolor et pavor
Copyright
Old 09-25-2022, 04:59 PM
