Recreational Mechanic
Nickshu's Avatar
After reading the above I am going to just get a new tank. Only $160 from Ford new (LOL...not Porsche parts prices!).
In order to get to the hoses or the pump to flush through and drain out something like Acetone I basically have to remove just as many parts as I would need to remove in order to replace the tank.
I decided to leave the original lines they probably don't have much in them compared to the tank and can flush out over time. Removing the lines give me a headache as they pass through various areas. Both a front camera sprayer and windshield sprayers. Hope I am right there. If I am not I can change the hoses later I guess as the flow path would not put any residue back in the tank.
Nothing but the cheap blue washer fluid for me from this day forward!!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 09-26-2022, 08:40 AM
Counterclockwise?
I hated the stuff. Always smeared when using intermittent wipers.
Did you call them to see if they will correct the problem? Can't just be you.
Rod
1986 Carrera
2001 996TT
Old 09-26-2022, 09:48 AM
Nickshu's Avatar
Called twice and left voicemails yes. Hopefully they will call back. I agree it can't just be me. Maybe that's why they have not called back yet LOL.
Old 09-26-2022, 10:32 AM
I had the same issue. Grabbed a gallon of Rain-X windshield washer fluid from Walmart when I was doing an oil change on the Yukon.
Wipers and washers were unusable.
I flushed the washer tank with a garden hose for 5 minutes.
Emptied tank with washer button.
Added 1 gallon of 50/50 solution of water and 99% isopropyl alcohol.
Cleaned windshield and wipers with ISO.
Added 1/2 gallon of straight ISO and ran half of it through the system.
Added 1/2 gallon of washer fluid to the remaining ISO in the tank and ran all of it through system.
I used the front and rear washers - alternating to let the pumps cool.
Now all is good.
Randy
'87 911 Targa
'17 Macan GTS
Old 09-26-2022, 12:58 PM
Model Citizen
herr_oberst's Avatar
This sounds WAY, WAY WAY better than using acetone.
Old 09-26-2022, 04:34 PM
Model Citizen
I hated that Orange RainX just because of the smell.
Old 09-26-2022, 04:35 PM
A930Rocket's Avatar
Yeah, but it makes a good breakfast drink.
Old 09-26-2022, 06:32 PM
Edministrator
Steve Carlton's Avatar
Pooping later is so easy!
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 09-28-2022, 09:59 AM
Nickshu's Avatar
So removed and replaced the washer tank yesterday. Bottom of the tank was full of Rain-X thick syrupy sludge. I don't think any amount of flushing would have gotten it out as the pump does not completely drain the tank. Removed the accessible hoses and flushed out w/ 50/50 isopropyl alcohol and water using a syringe. Did the same w/ the remaining hoses in the truck placing a rag overtop the sprayers. Installed the new tank. Wiped down the entire truck w/ 25/75 mix of isopropyl alcohol/water to remove the Rain-X that was sprayed all over (since I was on the highway at the time so it got blown everywhere but the tailgate). Installed new wiper blades. All good now.
Nothing but the cheap blue washer fluid for me from now on! What a PITA.
Old 10-02-2022, 06:05 AM
Counterclockwise?
Did the manufacturer ever get back to you?
Rod
1986 Carrera
2001 996TT
Old 10-03-2022, 06:42 AM
