Counterclockwise?
Transformer/adapter help please
My wife has a little tree with lights that she likes and the AC/DC adapter is broken.
I cannot find anything that goes down to 24V 0.1A. Can a different amperage be used? Maybe 12V 1.0A? This kind of electrical is not my thing. ![]() After me searching and finding nothing, she goes to Home Depot and the guy there sells her these plugs. lol The guy was adamant that they would work. He needs to be moved to the garden center.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Just get the voltage right and an amperage as high or higher will be fine. It will only use what it needs. It is just a maximum rating.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
canna change law physics
Fint is correct, it will only use what it is rated for. The rating on the transformer is the MAXIMUM load.
That voltage is the same as a door bell transformer. And those are available at home depot. $15 https://www.homedepot.com/p/Newhouse-Hardware-Wired-Tri-Volt-Doorbell-Transformer-3TRAN/308470453
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Platinum Member
24v doorbell transformer will work.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Counterclockwise?
Thank you gents!!
I'll see what I can find in 24 volts
Put a .5 amp fuse on that doorbell transformer output. your home insurance company will appreciate it.
1980 911 - Metzger 3.6L 2016 Cayman S |
Assuming that your plug is just physically broken and still works, some epoxy would fix that as well.
Counterclockwise?
Most of the doorbell transformers don't have a plug. Won't look very nice in the living room.
Are there screw lugs on the bottom of the transformer? What type of cable/connection runs from it to the tree decoration?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Counterclockwise?
Transformer is a glued unit without any screws.
Low amperage is probably due to the use of LED. Higher current will fry LED's without a resistor
dolor et pavor Copyright |
Counterclockwise?
These are not LED. The new ones are LED and are too bright, hence trying to keep this one going.
Ayo Irpin, Ukraine!
Rod, search Amazon for 24vdc wall adapters and they’re like $10 and you shouldn’t have to mess with the connector end. Best Buy used to have them as well. It’s a very common PS. As has been mentioned just make sure the Amp rating is over what yours is though I’d be very surprised if you actually found one lower than 100mA
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
Ayo Irpin, Ukraine!
They also carry adapter kits for various DC ends. The lower current rating on your transformer has nothing to do with it being LED or not… the load will pull what it needs. Just because one uses a transformer that can supply more current doesn’t mean that a LED load will be blown by hooking it up.
Counterclockwise?
This comment worries me. Is there a safety hazard?
Ayo Irpin, Ukraine!
Using that transformer?? IMO, yes. It’s meant for a high current draw and if you short it,,,,, I wouldn’t recommend that for what you’re doing if your original picture is of the transformer you are trying to replace.
Regular low current wall adapters have built in limiting. That’s why they are not externally fused.
Counterclockwise?
Platinum Member
Maybe, but that's DC. Depends on the tree electronics.
I'm confused...I read most of the comments.
The tree will only light when someone presses the door-bell??
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Counterclockwise?
Could catch.
