Counterclockwise?
Transformer/adapter help please
My wife has a little tree with lights that she likes and the AC/DC adapter is broken.
I cannot find anything that goes down to 24V 0.1A.
Can a different amperage be used? Maybe 12V 1.0A?
This kind of electrical is not my thing.
After me searching and finding nothing, she goes to Home Depot and the guy there sells her these plugs. lol The guy was adamant that they would work. He needs to be moved to the garden center.
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 06:34 AM
Send a message via AIM to fintstone
Just get the voltage right and an amperage as high or higher will be fine. It will only use what it needs. It is just a maximum rating.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-07-2022, 07:10 AM
canna change law physics
red-beard's Avatar
Fint is correct, it will only use what it is rated for. The rating on the transformer is the MAXIMUM load.
That voltage is the same as a door bell transformer. And those are available at home depot.
$15
https://www.homedepot.com/p/Newhouse-Hardware-Wired-Tri-Volt-Doorbell-Transformer-3TRAN/308470453
James
Red-beard for President, 2020
Old 12-07-2022, 07:16 AM
Platinum Member
dad911's Avatar
24v doorbell transformer will work.
Old 12-07-2022, 07:17 AM
Counterclockwise?
Thank you gents!!
I'll see what I can find in 24 volts
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 07:30 AM
3rd_gear_Ted's Avatar
Put a .5 amp fuse on that doorbell transformer output. your home insurance company will appreciate it.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 12-07-2022, 08:02 AM
Assuming that your plug is just physically broken and still works, some epoxy would fix that as well.
Old 12-07-2022, 08:06 AM
Counterclockwise?
That's what I did last time and when my 1 1/2 year old grandson pulled it off the wall it broke again. Grandma says no more glue. lol
Most of the doorbell transformers don't have a plug. Won't look very nice in the living room.
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 08:14 AM
MBAtarga's Avatar
Are there screw lugs on the bottom of the transformer? What type of cable/connection runs from it to the tree decoration?
Mark
'83 SC Targa - since 5/5/2001
Old 12-07-2022, 09:02 AM
Counterclockwise?
It's a table top tree and the wire comes from the tree and a plug (black) goes into the transformer.
Transformer is a glued unit without any screws.
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 09:10 AM
Arizona_928's Avatar
Low amperage is probably due to the use of LED. Higher current will fry LED's without a resistor
dolor et pavor
Copyright
Counterclockwise?
These are not LED. The new ones are LED and are too bright, hence trying to keep this one going.
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 09:14 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Rod, search Amazon for 24vdc wall adapters and they’re like $10 and you shouldn’t have to mess with the connector end. Best Buy used to have them as well. It’s a very common PS. As has been mentioned just make sure the Amp rating is over what yours is though I’d be very surprised if you actually found one lower than 100mA
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 12-07-2022, 09:17 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
They also carry adapter kits for various DC ends. The lower current rating on your transformer has nothing to do with it being LED or not… the load will pull what it needs. Just because one uses a transformer that can supply more current doesn’t mean that a LED load will be blown by hooking it up.
Old 12-07-2022, 09:19 AM
Counterclockwise?
This comment worries me. Is there a safety hazard?
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 09:25 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Using that transformer?? IMO, yes. It’s meant for a high current draw and if you short it,,,,, I wouldn’t recommend that for what you’re doing if your original picture is of the transformer you are trying to replace.
Regular low current wall adapters have built in limiting. That’s why they are not externally fused.
Old 12-07-2022, 09:39 AM
Counterclockwise?
This should work?
https://www.amazon.ca/ALITOVE-Supply-Adapter-100-240V-Converter/dp/B07VL8W6MQ/ref=sr_1_11?crid=3TBVD8TDN32VC&keywords=24%2Bvolt%2Bac%2Badapter&qid=1670428299&s=electronics&sprefix=24%2Bvolt%2Celectronics%2C85&sr=1-11&th=1
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 10:08 AM
Platinum Member
dad911's Avatar
Original looks like it has AC output.
Maybe, but that's DC. Depends on the tree electronics.
Old 12-07-2022, 10:45 AM
I'm confused...I read most of the comments.
The tree will only light when someone presses the door-bell??
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 12-07-2022, 10:58 AM
Counterclockwise?
Could catch.
Rod
1986 Carrera
2001 996TT
Old 12-07-2022, 11:25 AM
