jyl jyl is online now
jyl's Avatar
portable generator, txnfr switch?
Suppose you got a small portable generator (2000 to 5000 watt), and want to run the key stuff during a 12 hour to 2 day power outage: furnace (mine is gas with electric blower), water heater (ditto), cable modem, wifi. I don’t consider the fridge a key thing, and the freezer stays adequately cold for a couple days. I don’t need to light the house during power outages, with LED flashlights so long-lasting now.
Would the best (easiest, cheap, but safe) way be to run a subpanel with transfer switch, wire that key stuff to the subpanel, and power just that subpanel from the generator?
I’m not talking a whole house generator - this is for an urban house, we get outages of 12 hours to 2-3 days, but only every few years. 12 hours is NBD (flashlights, fireplace, candles, blankies, hot chocolate from the gas range). 2 days gets weariesome, and cold.
Old 12-23-2022, 07:34 AM
Seahawk's Avatar
We had a sub-panel installed with the necessary circuits breakers to engage certain circuits (water pump, refrigerators, sump pumps, TV, etc.) by an electrician. The plug for the electric cable for generator power (not whole house) is in the garage and the sub-panel right next to the main panel in the basement.
Very easy switch over. It is not automatic.
The generator runs just outside the garage when needed. We did have the cable from the generator to the plug made because I wanted to ensure the generator was outside when running.
It was less than a grand to have everything professionally done but that was over 15 years ago.
1996 FJ80.
Old 12-23-2022, 07:50 AM
I will be watching this!
I too want to get a small Honda inverter generator, and a practical way to hook it up to the house. Same thing, run the natural gas furnace, modem and router, and maybe the fridge for a hour or two if necessary. We have not had a power outage last more than a few hours in 24 years, except during one ice storm 10 years ago and a 12 hour outage then.
We do have a natural gas fireplace, but it is mostly decorative, and the only time it is lit is when the power is out.
My neighbor spent 12 grand on a Generac whole house generator installation and setup about 6 years ago. In 6 years he says it has been needed for 18 minutes total. That is some expensive electricity at 667 bucks per minute.
Old 12-23-2022, 07:53 AM
Seahawk's Avatar
5000 watts is a lot more juice than I thought, btw.
Instructions on the manual switch over are on the sub-panel as is a load management chart, meaning I can turn off certain functions (well water pump is a huge draw) and add others and still stay comfortably under the generators capability.
I like to stay cool, for instance, so I have a roll around portable 120v A/C unit I'll take off line when required.
The other thing the electrician did was keep a "tell tale" light so we know when power is restored...really handy to know.
1996 FJ80.
Old 12-23-2022, 08:33 AM
I see you
flatbutt's Avatar
Be wary of those that say backfeeding the panel is OK. Technically it is but you really need to be careful doing it that way.
Old 12-23-2022, 09:49 AM
Just thinking out loud
mattdavis11's Avatar
want to run the key stuff during a 12 hour to 2 day power outage: furnace (mine is gas with electric blower), water heater (ditto)...
I needed that water heater with a blower today. Hot water line froze. Cold side was fine.
91 FJ80
84 Ram Charger (now gone)
Old 12-23-2022, 10:00 AM
jyl's Avatar
I looked up watt draw of stuff like gas furnance blower, hot water heater blower - around 500 w typical. So maybe a Honda 2200 watt generator would be enough, to keep just the key things running. I read that genset runs for 8 hours on 1 gal gasoline. I’d only have to store 5-10 gallons. A power outage longer than 72 hours is very unusual here. The longest I’ve experienced in 16 years of living here was power out for 3 days
and cable internet for a week. (We moved into a hotel.) I’ve never been motivated to get any sort of genset. And to be honest, I still might not. But it’s interesting to think about.
Old 12-23-2022, 10:54 AM
Zink Racer
Have a transfer switch installed or maybe DIY that? I have two Honda EU2000's that are probably 12-15 years old now. Super quiet and reliable. We regularly take one in our travel trailer or both if we know we might want to run the AC. The only reason I have two in the first place was to run the AC at the race track with the dogs in the old RV. They can be tandem wired to produce 4000w. I don't have a switch at the house because we have a gas fireplace that can heat the living spaces adequately.
Jerry
Old 12-23-2022, 12:15 PM
expatriot98's Avatar
Make sure to have a main breaker lockout added to your main panel so you can't backfeed to the grid.
LGBFJB
Old 12-23-2022, 01:14 PM
greglepore's Avatar
There is a kit available that wires into your main panel, and has an "inlet" -to activate that you have to slide a switch over that cuts off the main breaker in the panel, preventing you from backfeeding the grid. You then plug the cable into your generator. You can manually control which circuits are fed by turning breakers on or off. You could do the same thing with a subpanel, sure, at added expense.
Like this:
https://www.amazon.com/GenSafety-Generator-Breaker-Panel-Interlock/dp/B09RGP1QR3/ref=asc_df_B09RGP1QR3/?tag=hyprod-20&linkCode=df0&hvadid=563702687488&hvpos=&hvnetw=g&hvrand=4231858892423159635&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008352&hvtargid=pla-1642387760306&psc=1
They're available for most panels. You do need space for the inlet circuit breaker.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 12-23-2022, 01:46 PM
My friends call me, Top
Skytrooper's Avatar
Well, I can chime in on this as I have been running a portable generator when we have power outages. I just finished a 3.5 hour stint due to the severe weather here.
When there is a chance of outages, I bring my generator in the garage. This way it is close and ready. When the power quits, I disconnect my dryer hose and run the 2 heavy power cords into the basement. I have 2 outlets closeby of which one is on the A side of the breaker box, the other on the B side. I start the generator...with nothing plugged in, so it can warm up to operating temperature. In the meantime, I switch off the main breaker and turn off what I do not need to power. Then I plug in the cords to the outlets described before and the generator. Hot damn...I got 220 power. Furnace and sump are primary circuits, well pump, refrigerator, and a few lights next. With the 220 I can dry clothes or run the stove. Those I can switch on if needed at the cost of turning off a couple others temporarily. I do all this on a 5k portable generator, and have been for 23 years.
I do long for a transfer switch though. It would make things much easier.
Matt
'87 924S
Old 12-23-2022, 02:35 PM
Preferred pronoun:Maestro
Norm K's Avatar
I was going to post the following hours ago, then the wind took out a tree down the street ... and the internet with it.
I recently completed such an install and, after weighing the benefits/shortcomings of the two, chose the less convenient option of an interlock device over a transfer switch.
Without going into the advantages of a transfer switch (and there are definitely some advantages), I went with the interlock device, primarily because it allows me to pick and choose which circuits to have on at a given time, an advantage that for me, outweighed those of the transfer switch.
My house is rural, and without natural gas service, is all electric - heat pump, water heater, range ... all the really energy-intensive stuff. I'd look at whole-house propane (had it in another home and liked it), but all of those items are essentially brand new and the cost of replacing them just means it doesn't make sense.
Anyway, because it's all electric, and because I might need/want the stove and water heater during the day and the heat pump at night, and because we definitely need the well pump, lights and communications at all times, and because I cheaped out and bought only a 13kw generator which can't power everything at once, I wanted to be able to select any of my circuits, not just eight or ten.
Yes, it's less convenient, but the ability to switch off one or two energy intensive circuits and switch that power to something different at any time, and within just a few seconds, made the interlock a better choice for me. If you're going with an even lower output machine it might be a good choice for you, too.
_
When in doubt, use overwhelming force.
Old 12-23-2022, 03:03 PM
jyl's Avatar
[QUOTE=greglepore;11879703]There is a kit available that wires into your main panel, and has an "inlet" -to activate that you have to slide a switch over that cuts off the main breaker in the panel, preventing you from backfeeding the grid. You then plug the cable into your generator. You can manually control which circuits are fed by turning breakers on or off. You could do the same thing with a subpanel, sure, at added expense.
Like this:
I like this idea. Prevents mistakes.
Old 12-23-2022, 04:47 PM
Arizona_928's Avatar
I was gonna recommend this one.
dolor et pavor
Copyright
Old 12-23-2022, 06:20 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
Timely thread (it is 5°F outside - without the wind chill - as I write this) and thanks for the suggestions.
I have a 4.3kW portable I got awhile back (actually as part of a service award from my company) and awhile back bought a natural gas adapter but never did any of the wiring or gas plumbing to outside where the generator would sit, largely because the gas line and the electrical service are on opposite ends of the house.
However this thread, and the extreme drop in temperature (53°F to 5°F in about 12 hours) has me thinking that I should do this sooner rather than later, forgo the natural gas hookup for now, and just keep an adequate supply of gasoline in the garage.
Old 12-23-2022, 07:24 PM
jyl's Avatar
However this thread, and the extremely drop in temperature (53°F to 5°F in about 12 hours) has me thinking that I should do this sooner rather than later, forgo the natural gas hookup for now, and just keep an adequate supply of gasoline in the garage.
Does your NG adapter also allow use of a propane tank?
Thinking about it, it seems more convenient to store propane than gasoline, if only because propane doesn’t go bad.
Old 12-23-2022, 07:46 PM
Last December when the big snow hit our area we were without power for eleven days. I have two generators and a bunch of extension cords. I got an estimate for a transfer switch set up at 2 grand. I’ll do it some day but for now all the extension cords will suffice.
Old 12-23-2022, 08:40 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Yes, and that's a damn good idea. I used to have a gas grill and those tanks had a very long shelf life. They are also readily available quite locally.
I wonder how long one standard (grille-sized) tank would last running my generator? It is rare that we have power outages, but we did lose power for a full week some years back.
Old 12-23-2022, 08:57 PM
Skytrooper's Avatar
I am thinking you would need something more substansial than a 20lb propane can for any outage of more than a couple hours.
Matt
'87 924S
Old 12-24-2022, 03:00 AM
rfuerst911sc's Avatar
Generally speaking a 10k - 12k propane portable generator will only run 3-4 hours on a full 20lb cylinder . Personally I wouldn't go any smaller than a 250 gallon tank . Remember all tanks are filled to 80% capacity to allow for expansion . So a 250 gallon tank when full has 200 gallons in it .
Old 12-24-2022, 04:49 AM
