FUSHIGI
Have been on ground source for over 20 years now. It was an initial investment and leap of faith for pay back. Installation expertise is really important.
Cults require delusions. |
I have inverter heat pumps in my shop they work great from zero to 98 F
I bought larger units then called for but I'm quite happy and the energy cost savings have been impressive
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R |
Yep I have a Mitsubishi 2 ton mini split in my 24x26 man cave garage . I have 10' ceilings but insulated quite well . It heats and cools very easily . It never sounds like it is working hard . If I run it 24/7 regardless of heating or cooling it only adds about 25 bucks to the electric bill per month . Hard to beat that .
11 years on my system. Total nightmare when first installed. They kept coming out to flush and bleed the ground loop, it kept getting air in it. They finally had to bring a mini-excavator in and dig a hole next to the house and fix a joint that wasn't glued properly. Of course, they hit the house with the excavator. Lucky the siding was new and easy to match. Of course, they refilled the hole by putting the topsoil in the bottom, and finished with sand. I still have issues getting the grass to grow on that side of the house, even after getting rid of some of the sand and bringing in more topsoil. |
UnRegistered User
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Glycol is not allowed here (poisonous) so our brine is 50/50 bioethanol/water.
Thank you for your time, Last edited by beepbeep; 02-27-2023 at 06:11 AM.. |
Detached Member
I have two of them on my RV, they are good to about 40-45 degrees, but in an RV the idea is at an RV park you are using their electricity instead of your propane. On a $150K RV they were a few hundred bucks, well worth it when ordering the RV.
Hugh |
My leak was a faulty King Valve.
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
Preferred pronoun:Maestro
_
When in doubt, use overwhelming force. |
This is a great thread.
If I have it correct - the AC (cooling) function of the heat pump is not necessarily more efficient than a normal AC unit. The potential "gain" is to be able to provide heating, to a point, without using NG or propane. Does it cost more in electricity to provide heating compared to using e.g. NG? Why not have an AC unit and a NG heater?
Sold: 1989 3.2 coupe, 112k miles |
I think ^that's^ correct in general.
_
But I'm not 100% certain on all of the details, and certainly don't have a dollar/BTU break down. And it probably depends on your location and market prices.
^^^ Nah, I think it was I who misunderstood you.
_
For geothermal, this is not necessary the case. My borehole delives brine at 5-ish deg C during the summer. There is an add-on where I can pipe that brine into fan convector in order to cool the house. Energy consumed is brine pump (around 80W) and convector fan (also around 80W). Theoretical "cooling" power of my borehole is around 10kW. You might be able to get half of it. But it is basically "free". Disclamer: Borehole temp will vary depending on yearly mean temperature at your location. So "free cooling" will not be as efficient in Arizona as in Minnesota.
Thank you for your time, |
