Arizona_928's Avatar
That looks exciting.
Did they not put a sealer on the outside?
dolor et pavor
Copyright
Old 08-05-2023, 12:11 PM
A930Rocket's Avatar
You don’t want very wet concrete, as that will weaken the psi mixture. After the footer is raised, talk to a concrete company or somebody that pumps concrete with a 2 inch line about what specific grout mix to use.
Old 08-05-2023, 01:12 PM
Yes, its sealed, drain tiled and a dimpled membrane.
Yes they pumped it in with a 2" hose.
Old 08-06-2023, 09:18 AM
Thanks for the help Rod, Rocket, Scott, Bill and Zeke!
dolor et pavor
Copyright
Old 08-08-2023, 06:31 AM
Originally Posted by ltusler View Post
See if there is a basement repair company in your area that will jack it back in place support it, install rebar in the block voids then pump in very wet concrete. Just had this done at out lake place. the lakeside wall had 1.5" of deflection.
Do you have any more pictures of the process? I find that very interesting for some reason.
dolor et pavor
Copyright
