ckissick's Avatar
Diesel engine failure: advice
It happens to be a 2013 diesel Cayenne, but it happens to all brands of diesels, apparently. It has 188,000 miles. The engine lost significant power so I took it to a Porsche dealer. They said the high pressure fuel pump failed, releasing metal shavings throughout the fuel system. It would cost $30K to repair, so the car is worthless now. Is there any known simpler fix? Anyone familiar with this?
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 10-05-2023, 10:15 AM
908/930's Avatar
I would talk to a couple independent shops, the dealer will want to change everything to new parts, needed or not. Are they also installing a new engine for $30k?
Old 10-05-2023, 10:47 AM
Team California
speeder's Avatar
It happens to all modern Tdi diesels with a HP fuel pumps, or at least it can. It happened to my VW but luckily it was still within the diesel gate warranty so it did not cost me anything. Now my car is throwing codes like a gang member in LA County lockup and I’m hoping that a tree falls on it, hopefully not with me inside.
If you are going to sell it as-is, send me a PM and maybe I’ll be dumb enough to take it on as a project. I’d have to find a crashed one with lower mileage that has not eaten itself yet. Good luck.
Old 10-05-2023, 10:52 AM
Common issue with modern diesels like already mentioned. One of my friends had his new Ram do the same thing and they had no replacement engines - said it was going to be at least 6 months for a warranty replacement so he ended up having to trade it in broken and buy another truck :-(
I swear this is caused by modern fuels. I use a diesel additive with almost every tank in my TDI. I also refuse to use a vw approved 5w30 in mine. I use Driven's DP40 instead.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 10-09-2023, 11:48 AM
ckissick's Avatar
Revisiting this...
The car is sitting in my driveway waiting for a mechanic, any mechanic, willing to work on it. No one wants to take it on. Back to the idea for a simple fix that I can take on. Can't I just replace the high pressure fuel pump and flush the fuel lines to get the metal shavings out? What else can be done? I see no reason to replace everything from the tank to the injectors. The car runs great until a sensor sends it into limp mode after maybe 30 minutes of driving.
Charlie
1966 912 Polo Red
1950 VW Bug
Old 12-06-2023, 04:37 PM
Registered ConfUser
Not a definitive answer but…why not? Nothing to lose at this point and may very well succeed.
Mike
Old 12-06-2023, 04:43 PM
Control Group
Tobra's Avatar
Yes, modern fuels are crap, diesel and gasoline.
Father in law runs the additive to the diesel fuel and is sort of OCD on maintaining his stuff.
His last Chevy had 400,000 miles of overloaded with a trailer that is probably too heavy, ran great when he gave it to his son, who promptly wrecked it.
Old 12-06-2023, 04:48 PM
Cars and Cappuccino
tdw28210's Avatar
Is a motor swap not an option?
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 12-06-2023, 04:53 PM
Arizona_928's Avatar
Originally Posted by ckissick View Post
Revisiting this...
A good shop will flush the lines and the tank. Replace/rebuild the injectors. When injectors fail, they burn a hole in the piston(how many psi are the common rail injectors? 30,000 psi?). New fuel pumps.
No one wants to touch that headache tbh. Especially if frugality is in the discussion. Don’t clean the system enough and you’ll grenade another fuel system.
Find a wrecked truck.
dolor et pavor
Copyright
Old 12-06-2023, 05:23 PM
Counterclockwise?
There are a mess of Cayenne's being parted out online. I've always wondered why.
Rod
1986 Carrera
2001 996TT
Old 12-07-2023, 06:43 AM
The cp3 in the Cummins 6.7 (stopped in the 2018 year model) are the standard for reliability in the common rail world. So reliability that kits exist to modify current CR engines for the cp3. Other failures such as fuel injector jetting a hole in the piston is the common failure for the fuel system.
Also there’s a kit that puts a filter on your return so if your vw hpfp poofs, it keeps the shrapnel upstream.
Why do these systems exist? Ask the nazis in California and the carb.
dolor et pavor
Copyright
Old 12-07-2023, 08:04 AM
A friend has a VW Touareg with the diesel. I think it uses the same HP pump.
The pump is a known and common failure point with the results you have. The roller gets cock-eyed and things come apart. That pump might be considered a "wear" item. Maybe some lube added to the fuel will help as a preventative measure.
Sold: 1989 3.2 coupe, 112k miles
Old 12-07-2023, 08:39 AM
Writeup here....
INCR-EA11003-61863
PDF (static.nhtsa.gov)
Old 12-07-2023, 08:49 AM
Counterclockwise?
Originally Posted by afterburn 549 View Post
Yes, a QT of MMO or ATF with every fill up (about 0ne to 30-gallon ratio)
1:30 ratio? That is a s#it load.
Rod
1986 Carrera
2001 996TT
Old 12-07-2023, 09:08 AM
Team California
speeder's Avatar
I know that diesels in general will run fine on ATF but I never thought of it as having much lubricity(?) Cleans everything in sight, that's for sure. There is a junkyard near our cabin in rural WI. where the owner has an older Chevy rollback/flatbed tow truck with ~500k miles on it and the guy claims that all he's ever run in it is used ATF drained from the hundreds of cars on his property.
Denis
Old 12-07-2023, 09:15 AM
Team California
speeder's Avatar
Might want to brush up on your math. One quart to 30 gallons is not 1:30 ratio.
Denis
Old 12-07-2023, 09:17 AM
Team California
speeder's Avatar
One QT to about 30 gallons sorry if I got it wrong
No, you had it right. But I used to add something a lot more oily, like a quart of outboard motor oil.
Denis
Old 12-07-2023, 09:18 AM
Counterclockwise?
More so my reading skills
Rod
1986 Carrera
2001 996TT
Old 12-07-2023, 09:21 AM
Early ones have the unicorn diesel.
dolor et pavor
Copyright
Old 12-07-2023, 09:55 AM
1:30 equates to the 1 x to 30 y = 31xy.
I’m not going to do the math.
AtF in a common rail too?!
dolor et pavor
Copyright
Old 12-07-2023, 10:04 AM
