Parrothead member
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
big blue tricycle stare down the darkness and watch it fade |
Parrothead member
You'd be amazed how many tree cutting chainsaw emergencies we respond to. People are clueless how dangerous it is.
Senior Member
Yes it is. It makes a circular saw seem like a toy. Treat it like a loaded gun. Never cut with the tip of the bar. Always use a very sharp chain. Gloves, eye and hearing protection. The whole nine yards. When the tree first starts to move, drop the saw and get away. if what you are doing makes you uncomfortable, hire a pro.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Counterclockwise?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I've ALWAYS shown chain saws and table saws for that matter great respect.
Parrothead member
Its not even just the chainsaw itself..
People are clueless how much a tree limb can actually weigh, and the reaction and movement when it falls. Iv'e had many trees on houses, vehicles and people themselves. A few fatalities also. .
Model Citizen
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
You do not have permissi
Keep it well oiled and never let it get pinched. A stretched chain whip is a nasty thing.
The real tree pros don't use ladders. I almost found out why..
Meanwhile other things are still happening. |
Non Compos Mentis
A chainsaw doesn't merely cut.
It gouges out chunks of flesh, and injects oil into the gaping wound. When I take a tree down, the first thing I do is plan my escape. As soon as it starts moving, I want to be as far away as possible. |
The only times I ever felled a tree w/out total topping when I was in the forest and had both a clear fall space and an escape route. I never felled w/out lopping off the limbs that would work against my notch. So many people fail to consider how limbs effect the way a tree will fall. Physics...it's real.
Tree fellers.
No, it was four actually. |
...walked into a bar?
