Update. Good news to report. After replacing the new aftermarket thermostat with an OEM Mopar and flusjhing the heater core (which was freely flowing) I vacuum filled the coolant and I now have heat. Lesson learned: Insist that repair shop use OEM parts as in my case the Radiator Cap and Thermostat failed immediately after the repair. Now, do I worry about the radiator, water pump and other coolant system componants that were replaced?
Thoughts of those parts going south will haunt you every time you drive your Jeep.
Sorry, that's just the way it is with me when I don't replace parts with the best I can afford at the time. |
New all aluminum upgraded capacity Mishimoto Radiator ordered. Yet another failure of an aluminum & plastic component |
What ever engineer was able to convince companies that the thermal expansion rate of aluminum vs plastic wouldn't matter, just to save some money on the assembly of a radiator, should be sentenced to replacing every one that fails.
I've never liked them and have and will replace with full aluminum if/when they fail. |
I work on Jeeps, we have an internal tech forum post regarding issues with non OEM thermostats on 3.6s.
We use dish soap to get oil flushed out of cooling systems, no issues using that. That engine has one or both blown head gasket(s). |
| All times are GMT -8. The time now is 08:18 PM. |
