-   -   Literally Stuck: Rebuilding a Vintage Girling Brake Caliper - Pic (http://forums.pelicanparts.com/showthread.php?t=1163234)
slow&rusty 06-19-2024 04:24 PM
Hey Guys - I am rebuilding the rear Girling caliper (1972 vintage). The piston is completely frozen in the bore.
I tried using the piston removal slide hammer tool (seen in the picture) with heat and zero luck.
Any suggestions??
http://forums.pelicanparts.com/uploa...1718839388.JPG
Thanks,
Yasin
A930Rocket 06-19-2024 06:07 PM
Soak it in PB Blaster and use air to blow the piston out?
Do you want to salvage the piston? I was thinking maybe use heat and PB Blaster with a pipe wrench or similar to break it free.
Is it square in the bore?
DRONE 06-19-2024 06:27 PM
The machinists in me says to put it on a mill and bore it out of course no more piston but a reusable caliper
ltusler 06-19-2024 06:28 PM
I've heard about pumping grease in but have'nt tried it.
Shaun @ Tru6 06-19-2024 06:32 PM
^^^ I used a grease gun once, it worked but was extremely slow. And very messy. Someday I'll build a proper hydraulic system with a brake pedal to push pistons out easily. Been very lucky with air on Turbo calipers.
A930Rocket 06-19-2024 06:33 PM
Any chance you can press it in to break the bond?
What about an ultrasound cleaner?
TimT 06-19-2024 06:34 PM
Use a vice or c-clamp and see if you can move the piston in, you'll know if it is moveable or totally frozen... If you can move it, use a grease gun, or hook it up to a brake system and use the brake pedal to force the piston out..
sc_rufctr 06-19-2024 07:41 PM
This and this. You have to get that piston moving.
(Obvious but...To use grease or air pressure you'd have to reassemble two halves)
pwd72s 06-19-2024 11:16 PM
A puller...to "pull" the caliper (held in a vise) through the piston? Actually then pushing with the puller screw? Good soaking with PB blaster first...
unclebilly 06-20-2024 01:47 AM
What penetrants have you tried?
You need to hit it with pressure. I hope the heat you have applied hasn’t damaged the aluminum.
GeorgeK 06-20-2024 05:00 AM
Soak in salted vinegar a few days?
Arizona_928 06-20-2024 05:08 AM
I’ve done it and it’s a messy process but it works.
Steve F 06-20-2024 06:34 AM
I used a hand held hydraulic pump used for various jaws of life tools, 10000 psi , worked great , just walked it out.
slow&rusty 06-20-2024 06:49 AM
Thanks guys.
I soaked it again last night with generous amounts of PB Blaster and then put a pair of vice grips on the piston and worked it back and forth and finally walked it out. The vice grips of course marred the piston, which is OK as I have a new piston and re-build kit.
I appreciate the help!
Yasin
