-   -   any modern gas cans that don't suck? (http://forums.pelicanparts.com/showthread.php?t=1163949)
masraum 07-06-2024 02:46 PM
I've had a couple of these, and they work REALLY well, no spill, easy to use, etc...
Except that after about 2 years, the seam on the handle develops a leak. And at $43/ea, I don't like only getting 1.5-3years out of them. I've had a couple of others that had the same issue or had some sort of wonky mechanism that only pours when the spout gets pushed in, and that mechanism is the weak spot.
I'm around ready for some metal cans with a short spout, but there's got to be something better.
masraum 07-06-2024 02:51 PM
I think I'm going to give a couple of these a shot. They are $65 here locally, vs $43, but they should last a lot longer.
https://assets.unilogcorp.com/187/ITEM/IMG/9655325.jpg
Robert Coats 07-06-2024 03:05 PM
No-Spill works quite well. The only complaint I have is the spring on the push-to-flow button is very strong, and will fatigue your finger(s) somewhat. It doesn't leak or dribble. I've had mine for 10+ years now and expect another 10 at least.
Available at most outdoor power equipment dealers.
https://i.imgur.com/3uwr7rz.png
https://nospill.com/collections/all
rfuerst911sc 07-06-2024 03:09 PM
I haven't had an issue with plastic gas cans but the nozzles suck . I buy these from Tractor Supply and like them . I use them on gas and diesel cans .
https://www.tractorsupply.com/tsc/product/ez-pour-1046800?store=2068&cid=Google-Local&utm_medium=Google&utm_source=Local&gad_sourc e=1&gclid=Cj0KCQjw1qO0BhDwARIsANfnkv_rEh7R6tuTDW8d 34aPebiqGJFNwIU61LECzxXq4i9QLvu0nQhG9Y4aAjnYEALw_w cB
Racerbvd 07-06-2024 03:14 PM
I use these, you can get them off of Amazon http://forums.pelicanparts.com/uploa...1720304047.jpg
Dixie 07-06-2024 03:20 PM
The Florida way.
http://forums.pelicanparts.com/uploa...1720304407.jpg
masraum 07-06-2024 03:22 PM
Yep, I really like those (I currently have 2, one new and one 2-3 yo).
The new one was a dud, lid doesn't completely seal, so constant slow leak while filling.
And the old one just sprung a leak between the two arrows in the photo (not my photo). I have had 3 other plastic gas cans fail in the same place and same way. (seam on the handle starts to leak).
https://i.redd.it/b4badlee1q8a1.jpg
masraum 07-06-2024 03:23 PM
I think my local hardware place has those.
dlockhart 07-06-2024 03:31 PM
https://tuffjug.com/
The quick fill is really nice.
I hot pit the zero turn.
Utillity jugs ;)
Racerbvd 07-06-2024 03:35 PM
Been using them for track events for Decades.
E38Driver 07-06-2024 05:22 PM
Tractor supply has them as well. 20 bucks.
Dave
red-beard 07-06-2024 06:36 PM
They sell kits to fix your gas can. Standard spout with a drill bit and vent hole cover.
A930Rocket 07-06-2024 06:54 PM
Originally Posted by red-beard (Post 12278904)
they sell kits to fix your gas can. Standard spout with a drill bit and vent hole cover.
^^^ +1
LEAKYSEALS951 07-06-2024 07:15 PM
http://forums.pelicanparts.com/uploa...1720318473.jpg
THIS is could be one of he best things I've ever bought.
Run lassie.... Run to amazon... NOW!!!! :)
masraum 07-06-2024 07:54 PM
What I need to fix it isn't a new spout. WHat I need to fix it is some sort of gas resistant RTV or JBWeld or something that bonds to the plastic of the can and keeps the handle from leaking.
The spout doesn't bother me and the NoSpill cans fill the mower really quickly.
What these plastic cans need is a relief valve that keeps the cans from inflating and deflating with changes in temperature which causes the handles to split/leak.
Evans, Marv 07-06-2024 08:53 PM
Truer words were never spoken. I discovered these some years ago and they're great. the little relief caps are easy to install too. They can be slightly loosened to let air pressure change within the can to keep the plastic handle area from splitting over time without letting too much fuel evaporate.
dlockhart 07-06-2024 09:39 PM
<iframe width="560" height="315" src="https://www.youtube.com/embed/gw0TVjl2sK4?si=uWwC_W-9J6o5ANbo&amp;start=127" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
wdfifteen 07-07-2024 03:02 AM
I bought a Surecan about 3 years ago. Love it! It drains from the bottom. I can set the can on the fender of my mower and fill the tank without having to stand there and hold the gas can.
If you are going to stand there and hold the can like the guy in the video does anyway, I don’t see the advantage.
https://www.surecanusa.com/product-page/5-gallon-gasoline-surecan
id10t 07-07-2024 04:57 AM
Son just got one intended for race use, he says none of those baffles etc that make current new cans a PITA
Seahawk 07-07-2024 05:25 AM
I have two these, one for gas and one for diesel, have for a long time. Some of the new gas cans look excellent, btw.
https://www.etrailer.com/Fuel-Transfer-Pump/TeraPump/TE34VR.html?feed=npn&utm_id=568114413&msclkid=f889 02029f48163b4ee8648818be55bf&utm_source=bing&utm_m edium=cpc&utm_campaign=Bing%20%7C%20Shop%20-%20Low%20Volume&utm_term=4577198194958136&utm_cont ent=Everything%20Else
Some pics of a few different kinds:
http://forums.pelicanparts.com/uploa...1720355034.jpg
