-   -   Any 964 ABS/AWD Experts Here? (http://forums.pelicanparts.com/showthread.php?t=1164507)
1990C4S 07-18-2024 10:00 AM
I have an ongoing 'fault' that occurs after a couple of minutes of driving, red brake light, red AWD light, and the dreaded bell.
I have some aftermarket software (Bergvill) that properly diagnosed my failed wheel speed sensor, and a faulty accelerometer, but I still have a persistent fault after several minutes of driving.
My Bergvill software does not seem to communicate with the ECU when the car is running, and when the car is OFF there is no fault stores.
The ABS pump seems to work properly when the key is ON, but after sitting it does seem to take a long time to shut off.
I have bled the brakes and added fresh fluid, I have not bled the AWD. It seems a bit tedious without a Hammer, but I think I should do it soon.
Anyone know enough about the 'ABS/AWD monitor procedure' to point me in the right direction? (I tried the 964/993 forum with zero success/suggestions.)
Planter91C2 07-18-2024 06:57 PM
If your speedometer is working, I would remove each wheel and clean the abs sensors from brake dust accumulation. There is 1 bolt on the top of each sensor, remove and clean. It could be your problem
group911@aol.co 07-18-2024 08:49 PM
Anybody near you that you could swap computers with? Your computer should be an "00" used until mid 91
1990C4S 07-19-2024 04:31 AM
Although my software tells me everything is good, I think this is a good starting point. I was also thinking of checking the sensor signal at the ECU end with a scope.
Seems unlikely that this is the problem, I didn't have any trouble when I daily drove it years ago, but I will check.
Planter91C2 07-19-2024 07:37 PM
Any update? Now I’m having the same problem 1991 c2
1990C4S 07-20-2024 04:53 AM
No, this is my 'spare' car, and I'm kind of busy right now getting my yard ready for a wedding. I might dig into it Monday.
1990C4S 07-22-2024 08:58 AM
I am going to start here, checking resistance of each wheel speed sensor at the ABS controller connector.
They should be about 1,000 Ohms.
http://forums.pelicanparts.com/uploa...1721663926.jpg
Planter91C2 07-22-2024 07:22 PM
I removed all my wheel sensors and cleaned them, they are like brand new 50k original miles. Let me know what you find out.
unclebilly 07-22-2024 08:49 PM
I had this exact situation. I took it to an Indy shop and the problem was… very slightly low brake fluid. It makes sense, every time I went over a bump, the lights would come on.
Top up your brake fluid and report back.
1990C4S 07-23-2024 06:09 AM
Thank you for the suggestion.
Never hurts to try, but I'm pretty sure I bypassed that sensor last year as one of my tests. But I'm willing to try anything that's easy...
1990C4S 07-25-2024 10:21 AM
Jumpering the brake fluid level sensor did not change the result for me, unfortuately.
I found three ABS sensors that read between 1,050 Ohms and 1,080 Ohms, but the front right was 1,700 Ohms.
I am looking online for a new sensor now, although my software does not tell me this is the problem, it certainly appears to be out of spec.
While I wait for it to ship I can drill out the bolt that held it in.... :(
