Trailer roof repair
A damaged enclosed trailer showed up on the local craigslist. A tree fell on it.
Walk away, run away, or simple fix? It wouldn't have to be 100% water tight, but could you straighten that rail, cut out the damaged area, and rivet on a patch? It looks to be all aluminum, or maybe everything but the frame, and that's what got me interested.
Old 08-06-2024, 05:16 PM
A930Rocket's Avatar
Seems like you could beat what you need to in shape, cut out the damaged sections and patch, using some kind of sealer (silicone?).
Instead of pop rivet, seems like a more watertight seal would be solid rivets. But then you would need two people, one inside and one outside, not mention the rivet shaping tools.
Old 08-06-2024, 05:35 PM
Platinum Member
dad911's Avatar
Weird tear marks for a tree. No damage to walls?
Looks to me like some carefull jacking/prying would fix the rails, and I'd piece in a new roof skin.
Is that a featherlite? If so, jump on it.
Old 08-06-2024, 05:56 PM
UnRegistered User
billybek's Avatar
Trailer from Jurassic Park?
Looks like the damage was from the inside out!
Old 08-06-2024, 06:33 PM
Bill Douglas's Avatar
Aluminium is easy stuff to work with. Even if it's not perfect, it will be on the roof so no one will see but the pigeons. And the inside will have the lining in place so you won't see that either.
Old 08-06-2024, 06:44 PM
Model Citizen
herr_oberst's Avatar
Pelican Tim Hancock rebuilt a Motor Coach that had terrible crash damage. Even as skilled as he is - and he is very skilled - I was thinking no way. He methodically worked his way through it and it looks terrific and he saved a siht-ton of money.
You've got this.
Old 08-06-2024, 09:21 PM
It'll be legen-waitforit
stealthn's Avatar
Good time to cut the roof off and put in plexiglass for the light
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 08-06-2024, 09:43 PM
rfuerst911sc's Avatar
Looks like a fairly easy fix . Cut out the bad , straighten any framework and rivet in patch panels . Caulk the perimeter of the patch panels . Clean the entire roof and apply white RV coating to the entire roof . Good to go for many years . I suggest white because it is cooler in direct summer sun light .
Old 08-07-2024, 03:19 AM
MAGA
Tim Hancock's Avatar
You've got this.
Here is a video I made showing how I tackled my roof damage on my coach project mentioned above. The underlying aluminum was mangled pretty bad. I just cut out the worst of it and replaced with new aluminum scabbed in pieces.
If you don't care if it looks perfect, this should be an easy repair. I would second what A930Rocket and rfeurst911sc suggested above and just beat it somewhat straight, cut out the bad sections of the roof and then patch with new aluminum patches and rivets. Maybe seal the patch edges and rivets with rv sealant roof sealant.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 08-07-2024, 04:41 AM
Counterclockwise?
Depends on just how cheap it is to buy.
Rod
1986 Carrera
2001 996TT
Old 08-07-2024, 09:20 AM
These are the kinds of threads I enjoy.....
Old 08-07-2024, 01:34 PM
Sold. Crap.
I have tomorrow off, I was all set to go look at it.
I guess it was a good deal.
Old 08-07-2024, 02:20 PM
