Nope, don't have one, and have seen them used in the videos. That certainly seems like the way to go.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Navin Johnson
When I do oil changes at home on my 07 Cayman, I just back it up onto ramps, and the oil change is a cinch..The car is near level with the pitch of the driveway, and rump being up on ramps..
I've owned my Cayman for 7 years, and have only used Liqui-Moly synth in it.. As for the spin on adapter... I asked my friend Bill about it (he's got 40+ years in the biz) link in my sig... and He rolled his eyes and said why the eff would you do that..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Which liqui-moly are you using? "why the eff would you do that?" LOL! I have no idea. I was curious myself. After watching some videos. I don't see a good reason for it.
Navin Johnson
Oops... the Liqui-moly I've been using is Motul x-cess G2 5-W40
I saw a jug of Liqui-moly in my shed the other day.. So at some point my Cayman used that
LOL. Both the LM and the Motul seem to be fairly well loved. I assume you can't go wrong with either one.
Gon fix it with me hammer
I used to have these drive on hydraulic ramps
![]() easy enough, drove on backwards, jack up easy access for oil on the Cayman but i've done so much work and cost saving, by now I have a 1 post lift. Totally worth it, getting to old to crawl around on my back for oil changes or any other work: ![]() Roof not high enough to stand under, but I have a stool on wheels, just as practical ![]() The post against the Wall, so it doesn't bother me, when not in use, I can drive over it and park 2 cars in as usual. ![]() I just left the canister system in place, its easy, I replace my oil every 5000 km.. 0w40 Mobil1 only. cost of the oil is cheaper than my engine if it blows up (even tho I have a low mileage spare block laying around just in case) I fill it till the last mark.. then I add 50cc at a time in between drives till the sensor say overfilled. That way I know its just a c*nthair over And if it ever drops, I'll know i burned off 50cc That has never happened in any of the 5000km stints. So I know mine don't burn, no bore scoring in my house !
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 09-28-2024 at 08:52 AM.. |
Those are really cool, and presumably, take up little space and are less expensive than many of the other options.
They were pretty heavy to haul out of the way since they are hydraulicly connected. And they typically have a ****ty pump and pistons that leak. I liked em when they worked, but found myself looking for a good hydraulic pump soon and those are expensive as F. , could easily have doubled the total price so ended up with the 1post lift which at 2500 is clearly more expensive, but way more practical. I look at it as a write off from 45 till my 65.. 125 a year is cheap to not be crawling under cars no more That lift is built for more usage than what I need, it won't wear out with my usage. I hooked up an IR beam sensor on my roof, that cuts out the pump when I the roof of my car hits the beam
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
What's old becomes new again...lots of 50's cars ran cannister filters.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
DK13HLQ ![]()
I was tempted to install the spin-on conversation on my 996. However, I was convinced to keep the canister filter since it is easier to inspect for metal debris. This is a big advantage if you are concerned about looking for an IMS issue.
I got the Mahle filter in the mail yesterday. I don't know why, but I was expecting it to be bigger.
And something that I'd forgotten about and ran across the other day, is Wayne's 101 Projects for Your Boxster which has a section on oil changes. Per Wayne, in the book, the spin on oil filter is actually an upgrade over the stock canister filter. https://www.pelicanparts.com/techarticles/Boxster_Tech/02-BASICS-Oil_Change/02-BASICS-Oil_Change.htm Quote:
Misunderstood User
I own a 944 Porsch. For years I changed my own oil. The filter is inverted and installed from the top. No matter how careful, it was messy. I can live with all of it - the issue is disposal. As I got older, I had it done by others. During the pandemic, I did change my oil. I'm now 70 and my body just doesn't bend like it used to. This really became a chore, and I still have the used oil and filter.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
undervalued member
I got one of these for my jeep because there is no check valve on the OEM cartridge filter housing, so all the oil drains out of the top end of the motor leading to dry starts. The 3.6 has valve train issues as is so it was worth the cost for this Baxter unit. Holds the oil in the spin on filter so it does not take the 4-5 seconds to oils the top end of the motor. Cool part is a schrader valve is incorporated so with 30 PSI plus from a compressor it evacuates the oil held in the spin on filter and unit back into the crankcase.
https://www.baxterperformanceusa.com/spin-on-oil-filter-adapter-1.html
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
![]() The 32 mm socket fits perfectly on the top of the cartridge.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
