Mike80911's Avatar
Carbon Monoxide leak
Last night I started to feel nauseous and had a headache I just thought I was getting sick so sat down to rest. About an hour later my CO alarm at the top of my basement stairs went off. Not putting 2 and 2 together I thought maybe it was an error, and I cleared it and put it back about 10 minutes later it went off again but this time the one in my basement also started beeping. I shut the boiler down opened up the windows and called 911. The fire department responded and found high levels throughout the house even on the second floor. They were great and extremely helpful they stayed until the levels went down to an acceptable level. Of course, had to happen on a Saturday night so now I am trying to find a boiler repair person to come here on a Sunday as we are without heat or hot water and it's 19 degrees outside.
If I did not have CO detectors (I have 5) or they were not working I am convinced my wife, and I would be dead. Please make sure you have working reliable CO detectors in your home and even your business. I even bought a CO reader like the FD uses from Amazon last night it gives a digital level readout. I figure after they repair it, I can check to make sure there is no leak.
89 930 Cab Black
11 Cayenne
Old 01-12-2025, 07:26 AM
It'll be legen-waitforit
stealthn's Avatar
Glad you and yours are OK!
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 01-12-2025, 07:33 AM
My other ride is a C-130J
RNajarian's Avatar
Thank Goodness you had the foresight to have several working CO monitors.
Great Advice. Glad everyone is OK
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 01-12-2025, 07:34 AM
+ lurking - contributing
Thanks for sharing your incident, glad you are ok. With gas heat and hot water, I have several CO detectors in the house and plan to order the digital reader per your request. Let us know what caused the rise in CO levels. My guess: has to be a bad heat exchanger or exhaust venting issue.
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-12-2025, 07:37 AM
Erakad's Avatar
Similar happened to me a couple years ago. CO detectors kept going off randomly. We'd check, open windows (not fun in winter), replaced batteries, but still random. Finally got the plumber out to check the boiler, again, nothing, all checked out. Then he happened to give the exhaust flue a squeeze and his thumb went through! After that, more squeezes and it crumbled. We were lucky
Rob
Black 1983
911 SC Coupe
Old 01-12-2025, 07:41 AM
Send a message via AIM to fintstone
I had the same happen with a tenant once about the same time of night. I am glad I had added functioning CO detectors to the older home a few months earlier. The fire department indicated deadly levels of CO in the house. The system needed replacing and since I did not trust the tenant to keep batteries in the detectors (unreliable tenant), I changed the system to electric heat (heat pump). disconnected the gas log, and got rid of the propane tank.
I sure am glad to hear that you/your family are all right. That was a close call.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-12-2025, 07:42 AM
Mike80911's Avatar
Thanks guys. Willam, I believe you are right I have not had anyone here yet but I have a direct vent gas boiler, and I think the silicone that seals the flue joints got old and started to leak causing the CO to enter the basement. Should hopefully be an easy fix. my boiler is 30 years old so I guess the silicone lived it's life span.
89 930 Cab Black
11 Cayenne
Old 01-12-2025, 07:46 AM
Mike80911's Avatar
You did the right thing especially as a landlord. I could not imagine someone dying in my rental property because I did not have CO detectors. I was thinking I should maybe add some electric slit units in the future
89 930 Cab Black
11 Cayenne
Old 01-12-2025, 07:49 AM
I had another rental (with an oil furnace) that I was renovating, and the workers doing the demo felt sick. It turned out it was the chimney/flue. The house (built in the 20s) had originally had a coal burner in the basement and a wood stove (cooking) on the main floor. When they converted the furnace to oil in the 70s, they simply replaced the coal burner with an oil furnace in the basement and used the same flue. They patched over the hole where the main floor wood stove entered the same block chimney used by the oil unit (no liner) and installed a small electric stove (boxed in the flue). It was leaking very badly.
I had the flue/chimney torn out and a heat pump with electric strips installed there as well. The oil tank was an eyesore, and the new system was much smaller (inside) so it worked out well. A heat pump also added A/C which was not totally necessary in that climate, but really nice for a couple months each year.
Old 01-12-2025, 08:15 AM
wdfifteen's Avatar
Glad you're OK!
Good reminder. Thank you. To tell the truth, don't know if our smoke detectors sniff CO or not. Is CO heavy or does it float to the ceiling?
Old 01-12-2025, 09:42 AM
Whew ... !
I've just purchased a new 2-pack Smoke/CO combined for my parents.
Ya want the smoke up high and the CO down low ...
These are primarily for smoke ... they will go up. Along with an existing CO down low in their bedroom.
Old 01-12-2025, 10:05 AM
Mike80911's Avatar
Glad you're OK!
They say CO is heavy and the detectors should be within about 14 inches of the floor. But the first detector to go off was the one at the top of the basement steps and the boiler is in the basement. There was also a high level all the way up on the 2nd floor. I have a detector in the basement that is close to the floor that one did not go off until the upstairs one went off twice. I have both combo detectors and the specific CO detectors the first one that went off was the combo.
89 930 Cab Black
11 Cayenne
Old 01-12-2025, 10:16 AM
Glad you're OK!
Most do not do both, but you can certainly buy those that do. If all yours are the same/match, it is likely that they are not as the ones that do both are usually more expensive and people usually do not send the extra money. Just google the part number off of one and the specs will tell you. I have one in each level of my home as there is a gas log in each...but the rest of the detectors are just for smoke/fire. Mine are mounted low upstairs but on the ceiling downstairs.
I bought all new detectors for my vacation home when I bought it (they are only good for 10-12 years...some less). I used the combination CO/fire ones throughout as I was able to get a good deal due to volume (hardware stores sell builder packs) and i liked that they all matched and operated the same, mounted the same, used the same batteries, etc. I chose not to use them for my monitored alarms (just regular smoke/fire detectors, as it is really only an issue when you are there...and they are reportedly more prone to false alarms.
Old 01-12-2025, 11:14 AM
If you have natural gas heat here, code requires CO at floor levels and how many depend upon house layout. The Smoke/CO combos which were common at the big box recently... up high at basement stairs, and upstairs, etc. Overkill and redundancy beats the theory of high & low .... or low & high or ???.
They will detect burnt toast..
after the house is gone
Old 01-12-2025, 11:26 AM
Smoke detectors were wired everywhere in my newer homes (pretty much every room and hallway) and replacement combination CO/fire were designed to swap right in with same base/wiring. It takes a bit more thought for the older homes and the wiring is not there. In most places, the requirements for detectors in existing homes in general (and more so for CO) are quite low (although you can add ones that work on battery alone (wired ones use a battery backup). I have had to meet code for rental homes (when I changed the use of the home) ...but usually try to far exceed the minimum. I like the redundancy theory...even in totally electric homes (which I greatly prefer for rentals).
Most folks should check the expiration dates on theirs as they lose effectiveness. It is usually on the back or in the battery compartment.
Old 01-12-2025, 11:37 AM
rfuerst911sc's Avatar
Our dual fuel heat pump/LP furnace is vented outside via PVC pipe . I am thankful for that . I am glad the OP and family are OK . Very scary .
Old 01-12-2025, 01:33 PM
Brew Master
cabmandone's Avatar
Typically the heat exchanger gets soot buildup and needs cleaned. If the system is venting properly, the silicone is pretty much for looks from my experience. Odds are if you're able to see the burner flame, it'll be lazy and yellow. I didn't do much with boilers but worked on a few for friends. Each time there was a problem I had to take the metal outer panels off where the vent pipe connected to the boiler and vacuum the soot out of the heat exchanger.
Nick
Old 01-12-2025, 01:37 PM
The pipe shouldnt need to be sealed at all there should be negative pressure in it. If it is blowing out there is a clog
Old 01-12-2025, 02:44 PM
Mike80911's Avatar
Thanks for the reply Nick. So you are saying if I remove the elbow where the vent connects to the boiler there might be soot built up in there. Here is a picture I should remove the elbow circled, correct?
89 930 Cab Black
11 Cayenne
Old 01-12-2025, 03:22 PM
Parrothead member
VINMAN's Avatar
Very untrue. CO is the same or just slightly lighter than air. It does not settle.
Detectors are better off placed closer to the ceiling. Especially around sleeping areas.
You should have a CO detector on every level of a residence.
Also, if your CO alarm goes off, DO NOT open up and try to air the house out. That makes it extremely hard for us to get the actual levels and source of the leak. Leave doors and windows closed , get your family outside and wait for us to get there.
Vinny
Old 01-12-2025, 04:12 PM
