Recommend A Power Washer?
Son broke the one we have at home. Yeah he should have been more careful, but maybe the fitting between hose connection and pump shouldn’t be plastic. Cheap little thing.
So I want to get a good power washer. A consumer model. Electric, suitable for use around the house and driveway/sidewalk, not going to be doing parking lots or commercial work with it. But I’d like it to be pretty robust. Recs?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Around here everyone seems to use a Kacher washer. Lots of different models depending on how much you want to pay and it's intended use of course. Nice and common and as they say the crowd is not usually wrong. GF has one and she thinks it's good.
Born to Lose, Live to Win
I have an Adam’s Pressure Washer 3.0. Had it 5 months and have used it a lot but I use it for detailing my vehicles although I recently used it to clean my siding and patio furniture and it’s fine for that too. I would buy it again
https://adamspolishes.com/
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 Last edited by ramonesfreak; 06-24-2025 at 04:47 PM.. |
^^^ I have something very similar and it works great. I don't have water at the equipment barns so I tow a 30 gallon water tank and get busy on battery power,
I haven't used the gas powered sprayer in years.
1996 FJ80. Last edited by Seahawk; 06-23-2025 at 03:42 AM.. |
I know folks will scoff, but my Harbor Freight unit is 8-9 yrs old and still going strong. I did have to cut off the integral gci on the cord as it failed, and recently the adjustable wand clogged to the point of uselessness. However, they've fixed the largest issue, the proprietary wand. You can now buy a $7 adaptor that allows the use of standard 1/4 heads and surface cleaners and real foam cannons. They're often on sale for $80 or so.
For home use in electric, they're a steal. Vevor has some similar stuff. I suspect most of the light electric stuff is very similar.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
We got a Karcher K3 earlier in the spring, works great, on wheels. It has a good, long hose, etc., well made. I think this model is still made in Germany (or was). It came off Amazon. It replaced an old Karcher model that finally died after an extended power washing session.
(the shotguns)
I have the dewalt that is about the size of a carry on bag. been using it for a couple years now iirc. main use is car washing, small areas of sidewalk and siding touch up along with deck cleaning are secondary uses. it is not strong enough for high volume sidewalk and is marginal for large areas of siding.
all that said I don't think I'll ever own a gas power washer again. Actually looking casually at garage wall mounted units. really no reason I couldn't use the dewalt for that I guess. main pita is the hose to the wand. just not terribly easy to store.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Counterclockwise?
If you want any real power you need a gas one, but I'm sure you know that.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I picked up a Honda powered PW at a garage sale. It is still somewhat anemic. All the dirtbike guys love the 120v powered washers because they are NOT too powerful. I think there are power graduations. Mine is middle of the pack. Electric is bottom. Big gassers are top. Match the power to the job. I don't think "robust" and 120v PW exist together. I think they are mostly consumable.
MAGA
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
I bought an electric Sun Joe from Amazon about 5 years ago.
Works great
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
Platinum Member
I've been happy with Karcher k1700 electric.
I also picked up a Bauer 20v from HF. Only 300 pounds of pressure, but it's great for car mats, wheel wells, and my decking. Gas power washer and my other gas tools (chainsaw, blowers, trimmers) have been sitting idle for years. Time to marketplace them....
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I see you
hmmmm...I've put off buying one as I don't want to over burden my well pump. Having a tank is a great idea as I can fill it from the pond.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
I would get the brand from who offers the best replacement policy.
nowadays they are all kind of crappy cheaply made. Can't beat 80 bucks though....
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Counterclockwise?
Careful. I blew my pump when it got clogged from lake water
I see you
Good tip, thanks.
Looking at this one. Electric, claimed 3000 psi and 2.0 GPM. It seems as close as one can get to gas-powered specs and what I can see of the hose connection points looks like metal. Spendy but the last one cost $100 and lasted less than two years . . .
https://www.lowes.com/pd/Greenworks-Pro-Greenworks-3000-Pressure-Washer/5001554495
disband
I've got one of the $80 amazon specials called an Arksen. Works good going on 5 or 6 years.
The other thing that will kill them is not priming them prior to turning the pump on. Pull the handle to flush the air with the water source pressure and only when the air is flushed do you then turn the pump on. My old neighbor burnt his up that way...
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Parrothead member
I've had Karcher's before, wasn't thrilled at all with them. .
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
