^^^ I might do that if the additives don't smooth it out.
I don't want to do a carb switch during the snow season....it might not go good and my shovel is not fun.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-14-2025, 08:20 AM
Took 20 minutes on my backpack blower.
Fired up first pull. $20 and 20 minutes to fix a $500 blower worked for me. I loathe messing with carbs - they are like black magic afaict.
gl.
Old 12-14-2025, 08:24 AM
Brew Master
cabmandone's Avatar
Worst case is back on with the old carb. I can't see a down side to a job that takes maybe 20 minutes.
Nick
^^^ 20 minutes...if nothing goes wrong.
I thought you would suggest getting this....
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-14-2025, 08:31 AM
Brew Master
cabmandone's Avatar
Nah. If I suggest something it'll be something with a cab and heat!
Nick
Old 12-14-2025, 08:44 AM
This guy shows an easy fix....I can do that.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-14-2025, 10:06 AM
Bill Verburg's Avatar
Just finished doing the drive....started good but had to let it warm up more because of the low temp. After about 3 minutes at a med idle, I opened it up and it surged, but not as bad. That was after adding a quart of TrueFuel.
After a couple minutes of surging...it leveled out. I'll add the Techron on Tues. and see how it goes next usage.
back in the day, Techron was the go to fuel system cleaner
surge usually indicates a lean mixture, which makes sense if the jets are gummed up
I just use non-ethanol pump fuel in mine, main benefit is little to no water absorption which is the main issue w/ ethanol fuel
Bill Verburg
Old 12-14-2025, 10:55 AM
^^^ Yeah...I've resisted using rec fuel because it's not readily sold at most stations here.
I'm going to start using it though....also it's 90 octane here instead of our 87 regular.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-14-2025, 11:34 AM
Cajundaddy's Avatar
Fresh Top Tier premium fuel for the season and run it nice and hot. After use turn off the gas petcock and let it run til the carb bowl is dry and she dies. I do this with all small carbureted engines to avoid shellacking the carb jets and float bowl. Ethanol blend is evil.
2021 Cayman GTS 4.0L
2020 Macan (dog hauler)
Old 12-14-2025, 12:47 PM
^^^ I don't see any 'gas shutoff' on my Tecumseh. I could drain the bowl, but the plastic cover that includes the ign switch, throttle and primer have to come off first. Could be done.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-14-2025, 12:55 PM
I like this one.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-14-2025, 04:15 PM
Mine was surging, needed a new spark plug at 17 years old. (already had a new carb, only run straight gas in it, always use Stabil for summer storage)
Brent
Old 12-14-2025, 06:13 PM
^^^ Going to switch to rec gas....not easy to find/buy it here.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-14-2025, 06:34 PM
I see you
flatbutt's Avatar
Originally Posted by Scott Douglas View Post
When I was growing up we had a Pontiac wagon that Dad used to pull our camping trailer. It had 10.5:1 CR and three 2-bbl carbs and would only run correctly on Chevron Custom Supreme that at that time had an octane rating of 101.
To blow the carbon out of it when it started pinging, we'd fill an orange juice can full of water and pour it down the middle carb while holding the throttle open at about 2-3k rpm. Carbon chunks would come out of the exhausts. It always ran better after doing that.
I try to run Chevron gas in our cars because it has Techron in it from the pump. So far all's good, and my V-6 has 10:1 CR.
I don't think you're going to get a cleaned piston like those videos start with, with the application of only one can.
My Dad used to do that too. The cloud of steam was mighty impressive.
Old 12-14-2025, 06:43 PM
Counterclockwise?
Did you put fuel stabilizer in before you put it away for the summer?
Rod
1986 Carrera
2001 996TT
Old 12-15-2025, 08:15 AM
Brew Master
cabmandone's Avatar
Something about that video where the guy drills the jet doesn't make sense to me. He says it's the air jet. That doesn't seem right. Adding more air doesn't seem like it would fix the problem when he says applying the choke smooths the engine out. By adjusting the choke he's cutting air and changing the mixture. That has to be a fuel jet he's making larger.
Nick
Cajundaddy's Avatar
Should be easy enough to add a shutoff to the fuel line between tank and carb just like a motorcycle. Running the carb dry is the secret sauce with ethanol blend gas these days.
I did that every day after mowing the lawn with my Honda mower and it kept all the carb jets clean.
Old 12-15-2025, 08:40 AM
Originally Posted by Arizona_928 View Post
Seafoam but it'll need to be pulled for a cleaning.
Probably can buy a Chinese carb for 15 bucks.... I always add a shut off valve on stuff like this so it drains the bowl on the last start up of the season.
I tried the Chinese carb for my lawnmower. It leaked like a MF.
I had similar issue living in Hawaii. Ethanol gas just sucks in moisture to the carbs. A guy that worked for me had an airplane with air cooled engine. He had to replace an entire cylinder and barrel for his engine due to the E Gas. Our solution was getting marine gas down where the SS Minnow set sail on a 3 hour cruise.
Ah Marianne...
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 12-15-2025, 09:10 AM
No...I did not. It started right up a few weeks back after sitting all summer...no problem.
The surging was a little more pronounced this season...that's my problem. I'm going to switch to rec gas, so that should keep it from getting worse yet. If not, I start with the carb.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-15-2025, 09:49 AM
I'll look at that this spring. The 5hp Honda engine on my Trac Vac has a shut-off....wonder why it isn't on a 8hp Tecumseh.
98 Honda Prelude
22 Honda Civic SI
25 John Deere X-590
Old 12-15-2025, 10:01 AM
