-   -   How to insulate gas fireplace (http://forums.pelicanparts.com/showthread.php?t=1187543)
DWBOX2000 12-24-2025 09:47 AM
I have a gas fireplace that comes in through a sun room and the back side in a mud room. The mud room borders the garage. I have a constant breeze of cold air coming into the sun room. The problem is there is the second pipe that comes into the fireplace. It has a gap all around it of about a 1/4”. The cold air feeds into that and has straight path from the top of the box. I bought rock wool to insulate the box but unless I actually touch the second pipe, I can stop the cold air. Any advice appreciated.
Por_sha911 12-27-2025 10:04 AM
fireproof foam insulation
google is your friend
craigster59 12-27-2025 07:46 PM
I've used this. Works like charm.
https://krakenbond.net/products/fireplace-sealant
john70t 12-27-2025 09:27 PM
3M also makes 'fire resistant' foam and caulk. Both colored red.
I've used it to seal pipe penetrations through walls and floors (behind cabinets etc). Required by code.
Not for use on exhaust pipe.
NY65912 12-28-2025 05:37 AM
Retort cement, not firestop
Zeke 12-28-2025 10:10 AM
I guess you didn't like the answers in your previous thread:
https://forums.pelicanparts.com/off-topic-discussions/1187544-rockwool-insulation.html
