-   -   electrician question (http://forums.pelicanparts.com/showthread.php?t=1188461)
jmaxwell 01-23-2026 10:06 AM
Hi all, I have a question for the brain trust. My wife wants to install a bidet in place of our current toilet. The toilet is in a small seperate room with no outlets, but it does have a couple of gfci (I think) as shown in the picture. Can I switch one of these out for a regular gfci with outlets?
TIA
Jackhttp://forums.pelicanparts.com/uploa...1769191560.jpg
MBAtarga 01-23-2026 10:35 AM
yes
Cajundaddy 01-23-2026 11:40 AM
Really odd to see 2 separate GFCI next to each other and no outlets. I wonder what for...
Steve Carlton 01-23-2026 11:52 AM
Big screen OLED, tuner, DVD?
Zeke 01-23-2026 11:54 AM
They control 2 circuits. One can be changed to a receptacle and the load side will be protected just as it is now.
That has to be a crowded box and by the way the GFCI's sit cockeyed tells me that is the case.
A930Rocket 01-23-2026 05:55 PM
Are those GFI switches or GFI’s for outlets?
They say switch on and switch off.
I’ve never seen one before.
E Sully 01-24-2026 04:33 AM
They look like dedicated circuit protection for something like a jetted tub with heater. If so, you cannot tap into them.
jmaxwell 01-24-2026 06:35 AM
Thanks for the opinions. We do have a jetted tub, so that must be why they are there.
wdfifteen 01-24-2026 07:22 AM
You beat me to it. We had the exact pair of GFCIs in our bathroom. They were for the heated floor.
jyl 01-24-2026 11:57 AM
I assume they are 240v if for a hot tub and jet/heater?
Why can’t you tap the incoming power for a small load like a bidet? Assuming neutral and ground are all there? Add a box next to this one?
Cajundaddy 01-24-2026 12:10 PM
Interesting. We have a heated floor in the master with a GFCI breaker at the panel. No 2 gang GFI setup like this.
E Sully 01-25-2026 05:14 AM
Dedicated or individual branch circuit by definition is only one device, no tapping in for anything else.
greglepore 01-25-2026 05:18 AM
Probably 120. 1800w heater or so on a jetted tub, 20a circuit. You fill the tub with hot water, its not like a spa...and the motor is smallish compared to an outdoor tub. On a seperate circuit from the heater.
