-   -   Plastic Radiator? (http://forums.pelicanparts.com/showthread.php?t=256902)
silver912e 12-19-2005 09:52 AM
Plastic Radiator?
My Nissan has a hairline crack in the top of its radiator. The radiator is plastic (that's a new one on me), so I bought a new one, but I need to limp along on this one until the weekend when I can do the install. It's leaking a little, and I was wondering if some crazy glue will get me to the weekend?
Any ideas?
Thanks.
(Damned water-cooled cars)
IROC 12-19-2005 10:00 AM
I don't know if I would trust super glue. Every time I have tried to "make it to the weekend" with a leaking radiator, it has come back to haunt me.
BTW, lots of plastic radiators these days...
Mike
notfarnow 12-19-2005 10:01 AM
Could you use a soldering iron to "weld" the crack up? I've done this with plastic bumpers before
M.D. Holloway 12-19-2005 10:07 AM
Chances are, the plastic is a thermo-set material which means once it has been processed and cured you can't melt it back. Plastics are catogorized into two families - Thermoplastics (which can be remelted and molded) and Thermosets (which can not be re-processed or remelted without draqstically changing the physical properties).
For high temp, automotive applications, thermosets are typically used. Not sure you will want to try a repair job to get you through.
id10t 12-19-2005 10:08 AM
You are replacing it anyway, why not try the raw egg sealer method for the weekend?
Superman 12-19-2005 10:09 AM
Duct tape? A bottle of Radiator Stop Leak? Bars Leak?
RANDY P 12-19-2005 10:16 AM
JB Weld the crack.
island911 12-19-2005 11:34 AM
Good advice. (epoxies haven't worked there for me)
I've done this (weld) to plastic radiators w/ good results. Tho' admittedly, I may have snuck-in some carbon fiber to add some strength to the area.
oh, try not to breath the fumes.
flyenby 12-19-2005 12:25 PM
every time I have used stop leak...........water pump bearing fails after that.............
