Kantry Member
Janus,
It is certainly possible. Don't discount, however, the great loads on such a valve system having to open and close through magnetic induction, reversing the direction of the device dozens of times each second, in perfect time. How big does your solenoid have to get to give you the speed & control you need. For the cost of the rare earth magnets to get the job done and possible ceramics to keep the valve weight down, you can machine and harden a lot of camshafts. It is possible we are at a cross over point between two technologies. We won't see electro valves in production for a few years yet, until some engineer finds a way to make them faster and cheaper. Les
Best Les My train of thought has been replaced by a bumper car. |
Cars & Coffee Killer
So...where can I get a Coates cylinder head for my 951?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
F1 engines don't use air pressure to actuate the valves - they have conventional camshafts. What they do have is air cylinders that effectively act as the valve springs. I don't think current metallurgy can come up with a spring to withstand those rpms without float, etc.
Someone years ago tried using electric solenoids to operate the valves, but their response time sucked. You only have to envision the speed and rate at which valves are opening and closing in our engines to see that this would take one heck of a solenoid valve to do it electrically. The fact remains that the conventional way of operating valves seems to work just fine. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
1967 R50/2 |
Southern Class & Sass
Computer controlled electric valves have been bantered about for at least a decade or two.
And don't worry about loads placed on poppet valves. Think of what could be done with individually controlled rotary, or even reed, valves. Heck you don't even need a throttle-body if you add direct injection.
Dixie Bradenton, FL 2013 Camaro ZL1 |
BMW had an experimental engine w/ electronically controlled valves. It didn't need a starter because the valves and injection could be sequenced in such a manner as to start it.
48vdc just like our boats
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Heres a diesel truck that did Pikes Peak in a camless NASA derived engine here
Tim 82 SC 90 C2 Yasowatt |
