E100 ethanol mid-engine rear drive car
http://www.obvio.ind.br/obviona/cars.htm
http://www.obvio.ind.br/obviona/012.htm http://www.obvio.ind.br/Novo_Site/pr...2_lateral2.jpg http://www.obvio.ind.br/Novo_Site/pr...2_traseira.jpg |
Sounds kinda like a Smart ripoff.
The problem with ethanol is that it costs more to make than it can be sold for; and that's not expected to ever change. Ethanol has huge, in the billions of dollars, of tax subsidies now.
That should be stopped immediately. |
CO and CO2 as a result of human activity are of no consequence. |
Gas is good for you?
Do you know what's in it? http://en.wikipedia.org/wiki/MTBE Quote:
MTBE is now banned in 19 of the 50 United States, and several more states have pending legislation to ban it. What's in your gas tank? +1 for Ethanol, a renewable fuel.;) |
Gasoline is good for me when it's used as a fuel, but it's not for any other use, except as a dangerous solvent. Ethanol is a solution to a non-problem, and it still costs more, and in fact pollutes more, to make it. Some folks don't count the fuel burned by the farm tractors and combines. |
One of the uses for mid-eastern oil is to passify environuts here in America; it replaces oil that could be pumped here. Drilling should be done every place where oil can economically extracted, but huge areas are currently off limits. That should end as well. |
Someone mentioned Brazilian ethanol as a viable supply if it weren't for it being blocked by tariffs or worse. That may be true, but you still don't have a solution for the reduced BTU's provided by ethanol, in plain talk ethanol is significantly less fuel efficient than gasoline even if the cost to purchase were the same. IIRC, about 40% less efficient. The costs of ethanol are extensively noted below. Ethanol discussion: http://nature.gardenweb.com/forums/load/sustain/msg0113331712037.html |
996 trubo..................
http://www.exoticcarrentals.com/imag...911-B-Rear.jpg Cayman S....................... http://www.autowonder.com/new-aw/wp-...ayman-back.jpg[img][/img] http://www.obvio.ind.br/Novo_Site/pr...2_traseira.jpg |
| All times are GMT -8. The time now is 04:08 AM. |
