mystery engine
Friend of a friend took me into this guys workshop; the owner wasn't there. In it was this engine. Anyone know what it is?
It's a flathead V-8 with a distributor set up for twin plugs. I didn't see the second set of spark plug holes.
Thanks,
Sherwood
Old 10-03-2006, 11:05 AM
Sultan of Sawzall
rouxroux's Avatar
Might just be my eyes or this monitor, but it seems to be missing 1 exhaust port according to those headers...
Maybe someone just bolted alot of parts together for a conversation piece? Inquiring minds want to know...
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 10-03-2006, 11:26 AM
Senior Member
Looks like an old 239 Ford Flathead. Note the hand crank screw on the crank pully?
This pic is of a known 239 Ford Flathead. Only real difference that I can see is of the distributor.
Old 10-03-2006, 11:34 AM
Surely a Ford flathead, but the distributor and headers have got to be mock-ups for body/chassis fitment
Old 10-03-2006, 11:36 AM
They had siamesed exhaust ports and, in some cases, intake ports. Pretty common at one time. VW guys extol the virture of "single port" and "dual port" heads for different applications. The single ports shared a common intake port that branched inside the head. I've seen this on an old Landcruiser straight six as well, with shared intake ports between the 2/3 and 4/5 cylinders.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 10-03-2006, 11:43 AM
Senior Member
More 239's. Top one is supercharged with Offy heads, bottom one just dual carbs.
Old 10-03-2006, 11:51 AM
Still Doin Time
asphaltgambler's Avatar
Back in the day when guys were running these on fuel they would machine an extra center exhaust port out of the top of the block to aid flow.
Old 10-03-2006, 01:25 PM
pwd72s's Avatar
The distributor a mystery to me...but look UNDER the flat "head"...shape looks a lot like the ARDUN heads of old...
Sidney Allard commissioned Zora Duntov (yes, the 'Vette guy) and a guy named Arlen Ness (if memory serves) to make them for his Allards...the ARDUN head converted the flathead to a OHV engine.
Old 10-03-2006, 11:32 PM
Jim Bremner's Avatar
not an ARDUN conversion, the Ardun's heads are tall so they can have valves in them.
The "ROADRUNNER & WILEY COYOTE "cartoon once had a bit in it that the coyote drove a dragster with an ARDUN in it
it's a 21 stud flat motor, and he's spent some cash on it.
My dad has a few flatheads, I was brought home from the hospital that I was born in 1966 in a Flathead powered 1940 coupe
Old 10-04-2006, 08:28 AM
pwd72s's Avatar
Then, what's up with that distributor?
Old 10-04-2006, 11:18 AM
Hell Belcho
Nostril Cheese's Avatar
heres an ARDUN flathead
Old 10-04-2006, 11:23 AM
Hell Belcho
Old 10-04-2006, 11:24 AM
F L A T H E A D PORN!
Old 10-04-2006, 11:48 AM
pwd72s's Avatar
Yeah, if you think Porsche heads can get expensive, try to buy a pair of Ardun heads...
Old 10-04-2006, 12:11 PM
Still Doin Time
After all that it might make 230HP.................if the rods and crank hold up. I do dig them but........... just no rpms OR power and fragile
Old 10-04-2006, 02:07 PM
Wish I had a photo of the flathead block to demonstrate,but the valves are up the top on the valley side and the exhaust ports run across [or down] thru the block. The center two ports are siamesed,There are only three exhaust pipe outlets. Big problem with overheating if you thrashed
the car at all! New generation of petrol heads coming thru.
I'm 69 years old!
Old 10-04-2006, 04:07 PM
Also came in 21 stud or 24 stud heads. Joe's pics show one of each.
Old 10-04-2006, 04:12 PM
Does any car here provide a clue? (same garage)
Sherwood
Old 10-04-2006, 04:16 PM
Yeah, the first one up top is a Ford hot rod ,so the motor would fit that,
or the 39[?] Ford on the floor--the middle one is a Lotus 6,and the other one ,of course is a Porsche 356.[Do I win a prize?]
Old 10-04-2006, 04:27 PM
"Do I win a prize?"
Yeah. You get to tell us what's up with the 16 plug-wire distributor.
Sherwood
Old 10-04-2006, 04:51 PM
