Custom User Title
Lame question
My wife does almost all of our "chores". I rarely do the dishes, never do laundry, and generally don't pick up the daily stuff.
I got out of this by electing to be the "once every 2-3 weeks housecleaning guy". I prefer this because it condenses everything I hate into 1 instance. Like pulling a bandaid all at once. Here is the lame question: Cleaning the bathtub. The fricken soap film $hit is like bonded on some sub-atomic level. The way that I currently get it off is by scrubbing that crap for like 1/2 hour. I've tried a few cleaners, and for all I can tell they suck. I need to know- is there some magic trick you know for this? Like, soak it in kerosene for an hour? Spray holy-water? Buy an orbital sander and use it? Seriously- any suggestions of things that have WORKED for you, no matter how weird. Also- I need to mention that I need to do this today.
Might want to have HER do it more often?
I just use any common household cleaner and the toilet brush, What does help is an after-shower misting product. Just spray after you exit and it does it's magic. BTW-I just cleaned the house today. Wifey is gone huntin' and the 911 is apart for repairs.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
least common denominator
Have you tried CLR?
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
If it is that bad in a couple of week...it sounds to me like you need a water softener.
My wife recently started using a cleaner called "Scrubbing Bubbles" and swears by it. It seems to work better than the industrial strength stuff on soap scum....but I do not know how it would fare with mineral deposits as we have a top-of-the-line water softener.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
CLR (calcium, lime, & rust) is good...also Lime Away in the plastic lime colored bottle...both are acids.
I use Klean-Strip Phosphoric Prep & Etch from Home Depot for ~$12/gal. Small pump spray bottle or old Windex-type bottle, etc. Good for removing super hard mineral/soap/gunk stains on all...I'm on a private water supply - hard water. By the time you finish spraying the inside of the tub, you can just wipe it down/rinse. I don't even bend over to clean a tub and/or shower stall. Spray acid, wipe down with a brush on a 4' handle/rinse. Zip, zap, zop.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
A Man of Wealth and Taste
Here in LV U don't need to be Geezus to walk on the water. Its HARD..with a Capital H...and it will fk up your shower glass pronto...I have sen wrought iron gates rust through after a coupla years like they were being driven on Salted Roads in the Mid-west. Block walls tend to disengrate, the water here is JUST BAD.
Copyright "Some Observer" |
It is. I'll make you a great deal on a house here.
Banned
brake kleen
Try miracle erasers from Mr. Clean. They will remove the scum - you will have to work at it but they will do the job.
Randy '87 911 Targa '17 Macan GTS |
Senior Member
CLR or the same stuff sold in the .99c stores. Works wonders...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
19 years and 17k posts...
Bar Keeper's Friend is the best cleaner I've ever found for everything except glass....
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Re: Lame question
We have very hard water, and get lots of deposits in the tub. Tried all the cleaners, they all sucked. Finally found the solution: Wet the tub, and then sprinkle baking soda all over it. Use a plastic scouring pad and a bit of hot water. Comes right off. Nothing else out there works as well, not even CLR. I'm in the same boat with housework. Mrs Notfarnow does all the housework & cooking. I'm off the hook when there are house projects on the go. We have a ~140 yr old house, so there are pretty much always projects
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Un Chien Andalusia
Simply remove the light bulb in the bathroom.
You won't see the soap line, I guarantee it!
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
Bill is Dead.
We had the same problem - atomic bonded tub scum.
I tried bleach, scrubbing bubbles, 409, etc, and all to not avail. Then my wife tried this stuff that a friend of hers recommended. The stuff WORKED. She sprayed it on, let it soak a while, and the tub rinsed clean.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Cars & Coffee Killer
My wife and I use liquid shower soaps--no soap scum.
When I moved into my apartment in college, I kid you not, it looked like the shower had not been cleaned in 5 years. (The slum-lord college apartment companies did not clean between tenets.) It was a dirty flat off-white/tan color. I had to scrub it for close to 3 hours, no chemicals helped. When I was done, it was a glossy white.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Since I make a respectable income (at least for now while the practice is going well) but my wife still makes considerably more than me, we have always had a relatively modern division of labor. Laundry and kitchen belong to her. I load the dishwasher and do the heavy stuff. I worked my way through college in the kitchen of a hospital, so I got to know industrial cleaners on a first hand basis.
Ring around the bath tub is not a problem. You're just not using the right product, and believe me, there is a perfect product out there for every cleaning issue. If the ring is hard water, then CLR (calcium, lime, rust) is the perfect product, as stated earlier. If the issue is every day grease, oil and grime, then use a bleach product. The Chlorox spray bottle product works wonders. It works in the toilet, tub, tile, etc. As far as the best all around bathroom cleaning product, Scrubbing Bubbles (a brand name) is really incredible. Really, the household cleaner manufacturers are working over time to make housework easier. If you have to work too hard cleaning anything, experiment and find a product that works. There is something out there that will do the work for you.
MRM 1994 Carrera |
Custom User Title
Update- I used CLR, and it was FAR better than the Lysol Bathroom stuff I used to use. It sort of gelifies the scum and then a stuff bristle brush, it was done. I used the CLR on my floor too, and it was clean as it has ever been. For giggles, I tried the brakekleen on the tub too- it DOES work, but with no windows in there, I felt the fumes might put me on a flight I can't afford.
![]() SO- for my type of scum, whatever it may be, CLR works fantastic. |
Dept store Quartermaster
I think you'll find that if you eat enough pie you'll not have to do these chores at all.
What is this "soap film" you speak of?
Cornpoppin' Pony Soldier |
