Spark plug...I cannot tell you how many times new tools have not started because of the spark plug.
Clean it first, check gap, and after that doesn't work, go buy a new one! Works every time.
1996 FJ80. |
Sez he got 'er going!!!!!!!!!!
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
ha ha
very funny! thanks everyone. I'll continue this in the AM. Gonna pull out the spark plug first and measure the gap.. .and then figure out where the carberator is. I appreciate your help - this board is great!! |
Ever get it going?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
Hi everyone, I haven't messed with it since last week ... no more snow here. the first i'll do is take the spark plug out and replace it.
Thanks for your help! |
Senior Member
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I did locate a screw under the carberator. It seems to be spring loaded. When i push up on it, nothing happens. there's a big storm coming tomorrow. Last edited by on-ramp; 02-13-2007 at 01:50 PM.. |
Feelin' Solexy
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
The spring loaded thing under the carb is often the float bowl drain. If you, you should get fuel out when you depress it. If not, no fuel is getting to the carb (most of these are gravity feed, so it would be a plugged line or filter). Are you getting spark with the new plug?
If so, give it a shot of starting fluid and see if it fires....The electric starter takes some of the voltage going to the coil. Try the rope pull a few times.....
Sorry that didn't work...when was the last time it ran? If it has been in storage since last year, did you use Stabil in the tank? If not, flush the fuel and add new. Check fuel filter as well. I'd use starter fluid first, however...if it starts and stalls, could be fuel. Also, I find that old fuel and electric lines crack and prevent starting. Bend and check. Good luck with the storm
1996 FJ80. |
the fuel tank is full with fresh gas. Last season I ran it until it was all out of gas, as instructed per manual. snowblower has less than 30 min. total running time. |
Did you turn the gas supply on....may or may not have one, but most do.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
I had trouble with mine this year. Got some excellent advice from the board and this is what I found.
There is a float bowl. Take the cover off the float bowl. If you have fuel in the float bowl, then you have a problem elsewhere. If there is no fuel in the float bowl, then you have a blockage going from the gas tank into the float bowl. You will need to remove the little plastic pin that lets fuel into the bowl. The pin is connected to the float. Pushing up shuts it off, pulling down opens it up. Pull the pin, open the fuel valve, and spray carb / choke cleaner into the spot where the plastic pin enters until you can hear it entering the gas tank. This is the first likely spot where the fuel is getting clogged. Now, if you have fuel in the float bowl when you take it off, you probably have blockage between the bowl and the carb. I doubt this though since you mentioned that you ran it out of gas last season. That's why it seams to point to the fact that you didn't drain the float bowl and you had gas residue left in there which then turned to varnish. If that doesn't work, I'm out of ideas from this end. Michael
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
Did you try the starting fluid??
What make and model?
Driver
Hey, in anticipation of the big storm coming tomorrow to the NorthEast, just a little snowblower safety:
Mind you, I have no personal snow blower experience. I grew up in SoCal, and have lived in apartments my entire time here in Boston. However, I do have a lot of experience with people who have whacked off fingers from sticking their hands in the output chute when the blower gets clogged. So, even if the blower is turned off, there may be some kinetic energy stored in the impeller blade mechanism. As you stick your hand down there to unclog it, the blade may be freed up enough to make another revolution or two. Enough to mangle your hand permanently. A surgeon may be able to stick it back on, but unless you're a salamander, don't expect it to ever work properly again. So just remember to turn the motor off, and USE A PUSH STICK of some sort, please.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 02-13-2007 at 02:21 PM.. |
Feelin' Solexy
no, i dont have any starting fluid.. Manual clearly states not to use any starting fluid. I guess I need to take this "float bowel" off to see what's going on. Hopefully all the fuel will not spill out onto the garage floor. for all it's worth , here's the model # Troy Built Model 31AE6GQ3711 |
