Dept store Quartermaster
Any electronics engineers in the house? Linear encoder repair questions.
I need help with the read head of an obsoleted linear encoder. We believe a portion of it is damaged and need to know if it can be repaired. I know it's a long shot but we're trying everything over here. If this makes sense to anyone I'll go into the details. Thanks.
Cornpoppin' Pony Soldier |
Re: Any electronics engineers in the house? Linear encoder repair questions.
*************************** '97 Saturn SL (tiny 1.9L bubble car) '98 Grand Prix GTP (4dr family car with a bite FOR SALE) '87 944S (Sold as a German engineerd money pit) '78 Chevy 4x4 (What I drive when everything else is broke) |
Well, it's 50" long linear encoder with a "read head" that travels along it and lets the servo drive basically know where it is(via magnetic pulse). There is a .004" air gap between the read head and the 50" scale that it reads from and debris between the two has eaten into the read head and it no longer works correctly. I am wonderingif these heads can be repaired or not. Or if diagnostic testing can be done to see what is actually wrong with the head.
We have a new updated encoder/scale on the way but it is 12-14 days out, so I'm looking to limp this thing until then if possible.
canna change law physics
Can you get a new/used read head for your model?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
FWIW the read head consists of three stacked boards and I believe them to be fine. Those boards plug into the actual magnetic reading head that is encased in a hard epoxy via eight pins. My wondering is if there is a likely culprit in these that I could try to repair. Or even a way to diagnose via the pins as to what's actually wrong with it. The mfg. is ZERO help... which is nice.
I know this is highly specialized stuff but hell, who knows it's worth a try at this point.
Greasy Member
Is the sensing tip extended from the rest of the assemb or is it flush? Also, can the mount spacing be adjusted?
I once worked on a similar system that counted spacing on an assembly line track, the exposed tip became damaged from debris. We re-ground the tip to the proper shape then adjusted the mount so the spacing to the track was correct. Not sure it will work for your situation, but I thought I'd throw it out there. -Nick ::edit:: Sounds like this wont work. Your post came through as I was typing
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. Last edited by many944s; 04-11-2007 at 01:55 PM.. |
Cornpoppin' Pony Soldier Last edited by lendaddy; 04-11-2007 at 02:02 PM.. |
MAGA
Lendaddy, I am going to be out of town tomorrow, but Friday I will check with our shop to see if they have any advise as I seem to recall similar issues in our machine shop in the past and we have some pretty sharp troubleshooters in our shop. We may even have some old encoders laying around. Is this off a milling machine? Just off the top of my head, but it seems if it reads movement, but will not home, maybe the problem is not in the actual scale unit?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Is there a way to use an external "home" switch and send the signal to where the read head home switch is connected? (bypassing the read head home switch)
Automation Direct sells all kinds of limit switches that aren't too terribly expensive. I was thinking something like this: http://web2.automationdirect.com/adc/Shopping/Catalog/Sensors_-z-_Encoders/Double-Insulated_(PBT)_Limit_Switches/One-way_Lever_with_Polyamide_Roller_Actuator
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
Would this happen to a Balluff or MTS unit?
My guess is that the sensor is a hall effect. This would produce a small signal pulse when the reader passes over the reference mark. This needs to be amplified for processing. All of this would be the same for the other read process, I suspect. My guess is that there is some special output line that is reserved for the zero reference. This would be on one of those three boards and feedback to the machine. You don't happen to have any schematics? It would be possible to suggest some things to check if you have this.
I really need to hope for a fix on my current head. Maybe I'll get some pics up this A.M.
We called Unico and asked if there was a way to trick the drive by supplting a pulse at the right moment (it's not that crfitical really) and they claim there is not...but I'm with you, it's looking for a signal of some type so why can't we just manufacture it? I'll call them again today. ThanksAnd we use Automation Direct all the time, great company!
I took the cover off and checked for continuity from the board to the control box and it's good. We are checking with unico on creating a signal via a device and trigger to "fool" it but the guys here think that will be expensive and difficult...we'll see.
Here is a brief on the read-head. It is the non-guide quatrature TTL type.
Because this is a TTL system, they are doing some processing before feeding an output to the motor. It should be very easy to "fake" the signal depending on the timings. It did not show from this picture the frequency of these signals. I could calculate it from the 025 code shown if I knew the speed of the head. (Is this fixed or changing?) For example, the 025 code is 25cycles/mm. If the speed was 1mm/sec (really slow), then the frequency would be 25cycles/sec or 25 hertz. All the other signals seem to be a phase shift (time delay) of the same frequency. Then if you knew the pattern that the motor is looking for when the registration mark is found, you could recreate this using a simple micro-controller. Good luck. I hope that you can get this working. I wish I was closer and could lend more of a hand. I love trying to engineer a workaround.
Also, the speed does vary. Would the surface of the coil getting exposed and possibly "shorted" via debris possibly cause damage to the board? Thanks!
