Originally Posted by Joeaksa View Post
I shoot RAW and it works beautiful. Photos are large (30-40 megs each) but my God the quality.
Joe
I shoot raw as well. 30-40MB? What kind of camera do you have? I thought that raw should give you an image that's approx the same size as the megapixels of the camera. IE, my Canon is 8.0 or 8.1, and my images are usually between 7.0 and 8.9
Old 12-25-2007, 07:26 AM
Originally Posted by 911pcars View Post
There's only so much one can do with an underexposed scene no matter if it's high res jpg or raw.
Here's one. Anyone care to try fixing it?
It's easier to "fix" if the exposure and the lighting ratio are closer to ok.
Sherwood
This one is so under-exposed, it'll be hard to fix. Also, since it's jpg and not raw, that'll make it even harder to fix.
Old 12-25-2007, 07:35 AM
If I had the raw image to work with it would have come out a lot better. Not only is this a jpg, but it's also only 18k which means that a lot of the detail has already been lost to the compression algorithm. The better the image that you start with, the better the end result.
Here's about the best that I could do with it. I'm far from a pro. I just tinker, novice at best really.
Old 12-25-2007, 01:33 PM
Steve,
Thanks for the effort. I just wanted to show that software can only compensate so far. As in film, the elements of an image must be recorded in order to enhance it. Software solutions only go so far.
Minimum threshold light for proper exposure is the solution. Bracket if in doubt.
Sherwood
BTW, that's me (far left) sitting next to my son at my niece's wedding.
Old 12-25-2007, 04:33 PM
Wickd89's Avatar
Fix:
Get a Nikon associated flash. Use a bounce or diffuser and you should be fine.
Get the best lens you can afford. Hopefully a fixed 2.8 or better.
Get a good filter (protection).
Use a lower ASA/ISO setting for 100 or 200.
Existing light is great, but for people shots, you really need people to pose and a tripod, etc...
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 12-25-2007, 06:54 PM
Stay away from my Member
campbellcj's Avatar
FWIW, the last 2 nights I ended up using the D200 pop-up flash in CLS "commander" mode with an remote SB-600 bounced off the ceiling. It worked far better than the camera-mounted SB-600 I used last year. I have an SB-800 on the way so I can try some true multiple-flash stuff next.
Merry Christmas everybody...
Chris C.
1973 914 "R" (914-6) | track toy since 2003
2009 911 Turbo 6-speed (997.1TT) | weekend weapon
1964 356C Coupe | family heirloom
2021 Tesla Model 3 Performance | daily driver
Old 12-25-2007, 10:29 PM
