Me like track days
Craig 930 RS's Avatar
Question Melting gold.......questions -
I want to melt 1/2 oz of gold leaf.....
Best method? Melting temp and way to melt w/o blowing it all over?
Suggestions welcomed !
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-15-2008, 09:04 PM
slodave's Avatar
It's probably not pure gold. Gold leaf, often is mixed with silver or copper, depending on the color.
Old 02-15-2008, 09:11 PM
Senior Member
Why?
Old 02-16-2008, 02:08 AM
I've sent bunches off to the melters but haven't tried it myself. Temp will need to be 1500-2000 F, depending on the alloy. An electric furnace would be best and some sort of ceramic crucible to hold the AU. A torch might be tough to control the temperature.
Jim
down to jap bikes that run and a dead Norton
Old 02-16-2008, 05:24 AM
Free minder
Aurel's Avatar
Found that, if it may help...
http://www.wikihow.com/Melt-Gold
Aurel
Old 02-16-2008, 05:29 AM
MBAtarga's Avatar
Wouldn't the gold leaf (assuming the sheets are usable as that product and not "scraps") be worth much more in that state than melted down?
Mark
'83 SC Targa - since 5/5/2001
Old 02-16-2008, 07:18 AM
Me like track days
They are small pieces, light as a feather.
Is there a torch you'd recommend for heating a crucible?
Something to add to the gold so it won't stick, or ?
All ideas welcomed, thanks in advance!
Old 02-16-2008, 08:25 PM
FUSHIGI
Don't put it in a brass freeze plug and heat it w/ a torch. Such was the fate of my father's H.S. class ring...by his own hand...reportedly turned into a chunk of "slag" that was pitched...brilliant
Old 02-16-2008, 08:46 PM
DP935 member
kycarguy 935's Avatar
Brass melts at 1652-1724 degrees and gold melts at 1946 degrees fahrenheit.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 02-16-2008, 09:26 PM
Re the class ring melted with the brass, it would still have scrap value, the karet %age would be considerably lowered.
Reminded me of a customer who was going to fix his wife's broken gold bracelett with his arc welder. fffffffffffft, vaporized.
Jim
Old 02-17-2008, 04:38 AM
Lightbulb Question about melting gold
When you melt down gold and after it is melted doesn't it become pure gold? By melting the gold it burns up all the impurities in it, right? Like for instance, if you melt down different types of karats of gold into one melting pot then doesn't it all merge together burning out the all the impurities that each gold piece had making it one pure gold piece? I don't know, just asking so I do know.
Old 06-26-2011, 04:46 AM
No, you just change the shape. I've sent a lot off to the smelters but haven't made a study of how it's done. There's some time and expense involved. That's why Kitco only pays $1365/oz for 24kt scrap when gold is $1500/oz.
Jim
Old 06-28-2011, 03:34 PM
ship it up here - I'll melt it for you
can't afford DSG
Old 06-28-2011, 03:37 PM
Zeke's Avatar
Wad the leaf up into a ball and beat it with a hammer. I bet you end up with a BB size of gold.
Old 06-28-2011, 04:42 PM
1966 - 912 - SOLD
lane912's Avatar
Fire brick
Propane torch
Borax powdered soap-
Place the small pile of "gold" on the brick as condensed as possible. Shake some borax on top. It acts as a flux and will help keep the metal clean and together. Gently aply heat melting the flux then the metal. Be gentle with the torch-
Old 06-28-2011, 05:30 PM
wdfifteen's Avatar
I love it!
I don't mean to get all philosophical, but the answer to a lot of life's complicated problems is to beat that crap out of something with a hammer.
Old 06-28-2011, 05:34 PM
id10t's Avatar
Ok - so what about things like the pins on older cpus? I've got a bunch of 'em, need a good way to remove pins from the die, etc. Snipping leaves too much on and sends too much flying.
Old 06-28-2011, 06:19 PM
White and Nerdy
Tervuren's Avatar
Most of the impurities do not just burn away - they are other metals and materials mixed in. Gold is very very heavy, so when melted, it stays at the bottom, and you can scrape away the top layer of other stuff. It takes multiple attempts to get gold to a high level of purity.
Shadilay.
Old 06-28-2011, 06:34 PM
Aren't the pins coated or are they solid?
Old 06-28-2011, 06:37 PM
Banned
micro thin plated
there might be a ounce in a ton of pins
only worth doing with china rate labor and no EPA
and tons of CPUs to deplate
Old 06-28-2011, 08:54 PM
