Acrobat pro help
Acrobat pro help
Maybe this is easy..? I have 5 Pdf files that i need to be combined into 1 pdf file How do i do it????? |
I'm using Acrobat 7...
File -> Create PDF -> From Multiple Files... Browse for the files and arrange as needed. Hope this helps. Dave |
Document, Insert Pages; then select the filename.
(on my old version). You can chose to insert after, before or at a particular page. |
Yes, thankyou all.....worked fine...
If you turn on the page view sidebar you can drag and drop them into place.
| All times are GMT -8. The time now is 07:31 AM. |
