Home of the Whopper
Hydraulic fluid for mid rise lift
So I just bought a mid rise lift. It needs a gallon of hydraulic fluid. What should I use and where can I get it? Can I just buy a gallons worth of brake fluid?
Thanks!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
my local parts store has it in gallon containers.
Do not use brake fluid! I have the fluid spec for my lift written the the fluid tank, if nobody comes through with the info during the workday.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
MAGA
Pretty sure my BendPak midrise lift called for simply ATF. Dexron III I believe. I have been using it several times a week for a couple years now with no problems.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Targa, Panamera Turbo
BK911 - send me a PM and I will get you some at no charge...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Actually, ATF or even engine oil will work fine. I would say half of the Cats you see digging holes use engine oil as hydraulic fluid.
Home of the Whopper
Thanks guys. The instructions simply say a quality hydraulic fluid. None of the local FLAPS had anything but brake fluid.
