Adhesive remover for Concrete
Ok the thread title sucks! What I'm doing is removing tiles (~15yrs old) off a concrete floor. They are obviously are held down with some sort of adhesive (yellowish if that helps). I want to clean off all the adhesive and put a good epoxy paint down instead. What's the best way to go about this?
I have some 3M adhesive remover I was going to try but I think it'll take forever soaking, scrubbing, repeating, etc. I'd like to do it quickly and in less then a days work if possible (~350sqft). PLEASE HELP....
Bill 997.2 |
First make sure it is not BLACK mastic. That stuff is (asbestos) a big NO NO and the EPA will get you.
Try water and a floor scrapper. Then muriatic acid.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
MAGA
Bill, I just stripped my painted 625sqft garage floor last weekend and applied Behr 2 part epoxy. I thought about renting a floor grinder, but instead went thru 4 gallons of paint stripper brushed onto sections then powerwashed till clean...... miserable job. After stripping the old "porch/patio" paint, I acid etched then used 2 epoxy kits. Looks great.... I hope it lasts as this was a PITA job!
I am "guessing" that the stripper might work on the adhesive also. You could try it on a small section to see.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
It's not black for sure. It's definitely yellowish, kind of a dried mustard color? Is this stuff water soluble? I'll try it and see...
Where would I get the muriatic acid? Never heard of that before, sorry I don't do this stuff everyday.
Bill 997.2 |
Use a scraper designed for this purpose, then rent a buffer and sand the floor.
JR |
get some dry ice, lay it on in areas, hit it with a hammer.
Tru6 Restoration & Design |
Any decent home improvement store will have the acid.
A true floor scrapper can be found at a tile supply house. The blade is a sharp thin piece of metal about a foot wide and has a handle like a shovel.
Bill 997.2 |
JW Apostate
There is an easy to use adhesive stripper from Home Depot. I forget the name, but it comes in a 1 gallon can and is a semi gel consistency. You need some thin plastic sheeting ( 4mil )
You spread the stripper out with a plastering trowel and cover with the plastic as you go. This prevents evaporation and produces maximum results. After it has set for 20-30 minutes, you pull up the plastic and use a wide, flat blade scraper to get it all off. You need an old dust pan and a plastic lined bucket. It's very messy, smells hideous ( wear a respirator ) and is slippery, so don't fall into it. It is very caustic, so wear gloves and rain boots, too. After you have scraped up most of it, use a commercial mop and wringer bucket. You'll need to go over it a few times to neutralize. The other option is to rent a 'shot blaster' instead. KT
'74 914-6 2.6 SS #746 '01 Boxster Last edited by trekkor; 06-16-2009 at 05:46 PM.. |
Shaun 84 Targa - Seriously? I can just see the wife show up and see me working in dry ice fog and wonder what the heck I'm doing! Oh, nothing dear... ![]() WOW! Good stuff guys. Thanks for the quick replies!
Bill 997.2 |
JW Apostate
This is the stuff:
I've stripped about 4,000 square feet with this stuff, recently. I recommend. KT
'74 914-6 2.6 SS #746 '01 Boxster |
It's certainly the most fun way to remove tile/adhesive. You will need a scraper too, and can always have fun with the dry ice and the kids afterwards if you have any leftover. Lots of great science experiments on the web with dry ice. How else can you remove tile and be the coolest dad? Fire maybe, but that gets tricky, and the wife will definitely be mad.
MAGA
The acid comes with the Behr Epoxy kit (Home Depot carries the kit). If yo uuse Rustoleum's kit you will have to buy the acid seperate (no big deal). The acid etches the surface of the concrete which gives the paint something to bite into. If you use the acid (and the stripper for that matter), you will need to rinse the floor afterwards prior to paint. The acid treatment is important for proper adhesion, but since this is indoors and will not have hot tires on it, you might consider skipping the acid.... I would not skip it though because you do not want to have to repeat this process in the near future if your wife gets p!ssed because the floor has some spots peeling.
I suggested the water first because water left on VCT tiles will pop them up if allowed to soak overnight.
Platinum Member
I used the following to remove Sealer from patterned concrete. It worked amazingly well, and is relatively safe/green (made from soy)
http://www.franmar.com/index.php?cPath=21 I used Soy Gel, but I see they also sell adhesive removers: http://www.franmar.com/index.php?cPath=22 |
How many sqft does that 1 gallon cover? I'm leaning towards this method. I'll probably put it on thick and not cover it, like Tim mentioned.
Bill 997.2 |
Bill 997.2 |
19 years and 17k posts...
I've used Simple Green and a pressure washer with hot water...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Platinum Member
Call them. I bought it from a local distributor. They may have something in your area.
