Odd noises at the house...
So for roughly a few months now, we've noticed a bizarre sound emanating from the exterior wall of our daughter's room and we're scratching our heads on what could be the culprit. The attic, wall cavities and exterior soffits have all been checked for openings and critters with no luck.
The sound in question, which seems to occur most of the time in the afternoon/early evening sounds like, for lack of better description, some old guy snoring in the next room. 2-3 "snores" in succession, then nothing for another minute or so. Since the attic and walls have been checked, the only thing we can think of to turn to next is what lurks on the exterior surface of the same wall. This happens to be where all power, phone, and cable lines connect to the house. Any ideas if this well executed setup is causing my noise? Thanks in advance. http://forums.pelicanparts.com/uploa...1248651156.jpg |
What kind of elec service connection is that? !!!!
Is there a tree branch lying on or touching any of those lines anywhere between the house and where they connect to the pole?
A little bit of wind blowing on it could make it saw back and forth across the line and cause it to resonate like a violin where it connects to the house. Also check for branches against that gutter shown in the lower left... less of a chance of the same effect, but worth looking (along the entire length of the gutter since the resonance could transfer around a corner and make the noise send the sound through the fascia to the side of the house where the other connections are). Good luck. Post more pix if that ain't it. |
My assumption was areas with snow. |
I think we've found the culprit. Thanks for the help guys.. |
Oh about your question.
What does the noise you mentioned sound like. It may be a loose connection at your service. I have run across that one before. |
Fairly standard looking connection for the NE.
That is one scary house connection....
Really scary.. Here the service goes into a weather head... then via conduit to the meter and breaker box.. |
ghosts
don't tell your family! Tell them it's just a gable vent vibrating in the wind |
Is it a continuous noise?
Is it intermitant? I would go outside when it happens and see if I can isolate it. Wouln't hurt to have your power company check out those splices. Could be something else but better to be safe than sorry. |
At odd times during the day a LOUD alarm clock would go off somewhere outside on the farm. Went on for weeks:
Woodpecker hammering on the steel pole supporting a mercury vapor light by the barn. |
A tree mouse, rat, squirrel or some kid of critter using the phone or electrical wires for transport.
Their claws or tail or ? is rubbing on the siding and making the noise. My 2c. |
I would say the wire rubbing on the gable.
And there is nothing wrong with the service. Typical cheapass overhead hookup. Ian http://forums.pelicanparts.com/uploa...1248658122.jpg |
Our house in N.C. is connected just like that also. Are the sounds on the inside or outside or both?
DAMN!!! That service connection scares me! :eek: I hope you've got GREAT homeowner's ins!
| All times are GMT -8. The time now is 11:35 AM. |
