M.D. Holloway's Avatar
You can't achieve the speed of light and here is why - in very simple terms in order to move, something has to get pushed or thrown in relation to something else. Going from a steady state to a moving state - a continuous change in the position of a body relative to a reference point, as measured by a particular observer in a particular frame of reference - a physical movement or change in position or place.
In order to sustain movement a constant change relationship has to be continuously established between a static against the dynamic. As speed increases the dynamic touches more static thus chnaging position at a greater frequency. This is achieved when the static is non-flexible but as the incidence of relationship between the static and the dynamic increases them properties of both change as well.
Remember, the dynamic and the static of made up of particles that are moving almost at a speed C (the speed of light). As dynamic closes in on C the particles do not have the same physical attributes at lower speeds in fact they no longer act like particles at all but rather a fog of sorts that move via peaks and troughs. Think of a falling chunk of silly putty. It behaves like a solid. If thrown at low speeds upon impact it would feel like a solid but at high velocities, s high speed photo releveals that it actually looks like a liquid and infact it beaves like one as well. Matter is like that as well.
Now, dynamic is cruz'n through and it has movement source (rocket, wheel, EM rail, et al). That movement source is made up of the same stuff its just being re-arranged physically by giving off electrons or bigger - regardless these are still 'things' moving near to the sppeed of light C. What ever is reacting, as speed increases it begins to behave very differently, more flexibility which requires even more energy to go faster. At some point there just is enough energy to help the dynamic displace and change position.
Moving at the speed of light would mean that the dynamic would essentially dissolve into the statics it is trying to displace.
Speed of light...impossible to do so for the dynamic.
Michael D. Holloway
https://5thorderindustry.com/
Old 09-18-2009, 11:41 AM
A Man of Wealth and Taste
tabs's Avatar
Since I have no desire ever to go to Pluto I simply don't care how fast we are going to get there (unless there is a buffet there). Secondly anything more then 100 mph on the ground or 500 mph in the air is simply toooo fast to be of any practical use to me. The Concord is out of service.
Since I can't spell simple words what would make anyone think I can do math...btw WHAT is calculus? Sounds Greek to me.
I truly am amazed at the HP some of you BOYZ have under the hood. I knew I wasn't talking to dummys. What also amazes me is the human condition, so many with HP under the hood and still fumbling around it the dark when it comes to your inner selves and relationships to the world.
There simply is more than the quanatative world, the physical universe. One day I imagine physics will start to delve into the unseen universe that occupies the space around us. We may call that further dimensions beyond the 4 that we physically occupy. I also imagine that our portal to that unseen universe is accessed through our imaginations. If you have any doubts just take a look at how and when Einstein came up with his Theory of Relativity.
Copyright
"Some Observer"
Old 09-18-2009, 12:15 PM
Schumi's Avatar
Yes- tell you teacher we, PPOT, want a harder problem. Work him over- ask that, if we can solve it and explain it to you enough that you can in turn explain it with confidence to him, that you can get bonus points.
Worth a shot.
I'm breaking out my partial differential equations book right now. We need to get some collective PPOT gears rolling here...
M
Old 09-18-2009, 12:24 PM
beepbeep's Avatar
Dudes!
The exact answer is 0,0257c (I assumed 1g = 10m/sek^2 and half distance to Pluto to be 20AE). It's already solved in 8:th post. You don't need to solve two equations, there is already a shortened equation. If you know start speed, end speed and distance then acceleration can be presented this way:
As we already know the acceleration to be 1g = 9.78m/sek^2 and that start speed v0 = 0 then it's simply a matter of calculating v.
v[m/sek]= sqr(a[m/sek^2]*2s[m])
v being so low compared to speed of light, relativistic aspects don't come into play. As pazuzu said before, Lorenz Factor is almost 1 so it's not worth crunching it from relativistic point of view. Now give as a real problem!
Thank you for your time,
viking911's Avatar
Its been longer than I care to admit since I've taken quantum mechanics but from what I remember, in layman's terms, an object becomes more and more massive as it approaches the speed of light. Thus, it would require an infinite amount of energy to actually attain the speed of light. When an object gets close to the speed of light you have to throw out classical Newtonian physics and start using quantum mechanics, like the Lorentz transform. Typical high school problem, they don't give enough info. I'm an electrical engineer and have taken bunches of advanced physics and calculus classes and every once in a while I can't figure out how to do some of the goofy problems my teenagers come home with. Teachers don't give enough info or give the proper assumptions to know how to get the answer the teacher wants to see.
Now, you could warp space in front of the spacecraft, making an intense gravitational field in front of the spaceship, which would cause the ship to be constantly sucked foreword. This is why the Star Ship Enterprise" has its warp engines positioned so far away from the hull of the ship (so that the whole ship can fit into the warped space).
1976 911s Targa
Old 09-18-2009, 12:25 PM
Originally Posted by beepbeep View Post
Dudes!
The exact answer is 0,0257c. It's already solved in 8:th post.
I try to not hand absolutely everything out on a silver platter when someone obviously wants us to do his homework for him...
A better view is that an objects potential energy increases, so it requires more kinetic energy to accelerate said object. When working in relativity, we tend to get away from the concept of "mass" and convert everything into energy, to simplify the various equations.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 09-18-2009, 12:30 PM
MBAtarga's Avatar
Originally Posted by Porsche-O-Phile View Post
Why would you want to go to Pluto when you can go to Uranus?
You've got it all wrong! You want to go to Her Anus!
Mark
'83 SC Targa - since 5/5/2001
Old 09-18-2009, 12:53 PM
Axeman's Avatar
Originally Posted by LubeMaster77 View Post
Boobs... thats the answer...
+1 you can never go wrong with boobs!
Old 09-18-2009, 02:03 PM
austin552's Avatar
She came from planet claire.
1974 911s
Old 09-18-2009, 02:14 PM
Immature Member
dentist90's Avatar
I'm missing something here. In this equation does 's' represent time, in seconds? 'Cause it seems we have two unknowns to solve in that equation: terminal 'V' and 'S'. The instructor has given us a distance, a starting velocity (assumed to be 0) and a rate of acceleration. We have to solve whether V=c when that distance approaches, but we would first need to know the value of 'S' for this equation. What am I missing?
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 09-18-2009, 05:03 PM
Un Chien Andalusia
Aerkuld's Avatar
If you traveled to Pluto accelerating at 1 gravitational pull and then at the halfway point started deccelerating at 1 gravitational pull would you ever approach the speed of light?
What a goofy question.
Just because you're talking about physiscs and gravitational pull why do we have to assume you're talking about a planet?
I actually think Pazuzu's original answer is correct.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 09-18-2009, 06:15 PM
is it possible to exceed the speed of light?
Chris
the more i learn, the less i know
Old 09-18-2009, 08:06 PM
Nope
bummer
Chris
Old 09-18-2009, 08:31 PM
slodave's Avatar
Kind of. Light pulses and sound pulses have broken the light barrier.
http://physicsworld.com/cws/article/news/3630
http://www.msnbc.msn.com/id/16599496/
Old 09-18-2009, 08:40 PM
three times the speed of light isn't kinda
Chris
Old 09-18-2009, 08:45 PM
slodave's Avatar
The "kind of" was referring to the fact that it does not beak the law of physics. What do I know, I just Googled .
Old 09-18-2009, 08:54 PM
Registered Usurper
DARISC's Avatar
Every single FKNG time I approach the speed of light I approach infinite mass and I FKNG HATE IT!!
'82 SC RoW coupe
Old 09-18-2009, 09:09 PM
I guess the question is not if it is possible but rather why would you want to?
Michael D. Holloway
Old 09-18-2009, 09:44 PM
beepbeep's Avatar
nope, "s" is "stretch" (It's a "swedish" equation, "s" means "sträcka")...you use it when you know starting velocity, ending velocity and distance.
As you already know acceleration "a", starting velocity "v0" and distance "s" you need to break out "v".
Old 09-19-2009, 01:11 AM
