Plug a hard drive in with USB?
I saw someone mention a dock or kit that would allow you to plug old hard drives in with a USB cord? I have found some old drives that I want the pictures off of...
I find several on Google... Whats everyone else using? |
Mine is made from Vantec. Cheap, found it at Fry's. It has connections for SATA/IDE. I use it for both desktop drives and laptops. The only bummer, is that the transformer that came with it sucks and won't power up a desktop HD. I have a spare power supply that I use.
http://www.vantecusa.com/front/product/view_detail/266
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
External Drive Case
I was in Best Buy last night and noticed that they sell external hard drive chassis that will allow you to install a hard drive and connect it via USB. I don't think it will be any easier than installing it directly in your PC though - which you should be able to do for free.
I just pulled the hard drive out of my external chassis and installed it directly in my PC - the chassis went bad and wasn't connecting (no USB) or powering up the drive anymore. I pulled it out and installed it in the second bay of my PC - there is nothing unique about the drives in the external chassis - you can install them externally or directly inside your PC. Good luck.
Don "Gordo" Gordon '83 911SC Targa |
I don't want a chassis... Just a plug and a power supply... Need to get some stuff off these drives for my folks and their PC is in a hutch thing... easier to buy a cable...
Alii&Maui
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
Senior Member
Find them at Frys, good electronic store or Ebay. I use mine all the time.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Custom User Title
you can also just buy the cable and power but I thinks its easier to do the USB drive enclosure. |
![]() Very, very useful if you can't be bothered to mount an old drive in a case and reboot the OS just to access a couple of files. Plug it in, mount it (if necessary) and you're done. I bought that one (USB->SATA/IDE 2.5"/3.5"/5.25") as soon as I saw it, even though I already had several of the USB->IDE only ones (about half the price, or $6). Works great. USB 2.0 to SATA + IDE (2.5/3.5/5.25") Cable Adapter 2020
'77 S with '78 930 power and a few other things. |
Won't I need a power supply for that?
Newegg.com - SABRENT ECS-STU35K Aluminum 3.5" USB 2.0 Black External Enclosure - External Enclosures
There is what I am thinking... |
Senior Member
Depends on the hard drive. If its a full size desktop drive, usually yes. If its a notebook drive then no.
I have a spare power supply around the shop that I use for times like this. Plug it in, power up the drive to be accessed then plug the USB cord into the server. Access the drive then unplug everything. Used it last week to access a HD I am formatting for a friend and copy the OS to while getting ready to overhaul his computer. Works like a charm.
Not entirely true for laptop HD's. The SATA HD's need power. The old IDE's do not.
Senior Member
I must have a fancy adapter. The SATA for my new 17" Dell works fine in the adapter with no external power supply. It must come from the adapter.
My adapter requires a sata cable to plug in a drive, so it also needs an external power source. Does your adapter just plug into the drive?
Ok good to hear that dave... Ok back to the drawing board... I have several PC power supply laying around... Think they are all the ones that got nailed by lightning....
Senior Member
Got this at Fry's years ago. Been worth its weight in gold, or Porsche parts!
winter-hater club member
i have a SATA and an IDE enclosure. they work great. they have their own power supply that powers the drive.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Only for 3.5/5.25" drives. Laptop drives don't have a separate power connector and don't draw so much the USB bus can't power it.
For larger desktop drives, it comes with a power brick that uses a C14 power inlet and a "kettle" lead (US power to a C13 connector). The outlet is the "standard" keyed 4-pin HDD plug you find on the motherboard flying power leads in the disk bays, with an adapter for SATA desktop drives.
None of the drives are laptop drives... So I need a power supply....
