Targa, Panamera Turbo
Prime Example of Fatigue Failure...
Another text book example of a type of failure - fatigue. I took this pic last week with my cell phone. A snapped shaft due to fatigue.
Fatigue is the progressive damage that occurs when a material is subjected to cyclic loading. The maximum stress applied is less than the stress limit of the material yet the material is subjected to a constant or random elongation, bending or compression which will eventually take its toll and produce a failure. Notice the twist patterns as well as the color differences on the below pic: ![]() Typically, a fractured piece will have a dark area which is an indication of slow crack growth, and a bright area which is an indication of sudden fracture. Fatigue begins with the crystalline structure experiencing dislocation. Eventually small micro-fissures develop which begin to compromise the physical integrity of the part, tool or material. Many materials will not normally recover if fatigue is relieved. So, answer me this students-o-failure, why would the color be dark on the inside and not on the outside? How do you think the stress developed?
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
You have it back wards. The dark area is the area of sudden rupture while the brightly colored area is or slow crack growth. The crack initiation was at key-way and progresses inward as indicated by the "beach" marks. the dark area is of dimple rupture where the crossectional area was no longer large enough to handle the load and therefore the material Yield and UTS were exceeded.
I'm guessing that the color change ordinarily is a result of fretting and the color is from oxidized (very small) particles of the parent metal. Did this shaft stay together after the break?
The failure looks to have originated at the keyway. Was there a scratch or gouge in the bottom? I think I see one in the picture. I also see cracks starting to form at the corners. Was the key a bad fit in the slot? JR Last edited by javadog; 05-17-2010 at 11:46 AM.. |
A dark area from slow crack growth could be from oxidation on the cracked surface along with the two opposite fracture surfaces fretting together and wearing away the beach marks, but that's not the case here.
I'd say the fatigue crack in this shaft grew pretty fast as evidenced by the relatively wide spacing on the beach marks by the key.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Capitalist and Patriot
I'm not an engineer (wish I was tho) and I didn't sleep at a Holiday Inn, so my ignorant guess (in euber layman's terminology) is the dark color is from heat as well as a collapse or degradation of the molecular structure of the metal (tearing it self apart and compacting on its self) as it fractures?
The brighter outer area is a faster fracture and experienced less compressed energy when fracturing? pretty lame right?
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Feelin' Solexy
Cool pic!
Here is one of my 944 axle after suffering a failure:
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
MBruns for President
Looks like a cat - and why is it smiling at me?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I thought it was a breast implant that had been USED too much.
I have been in OT for way too long.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Information Junky
So, in engineering terms; Like a Ho-Ho ... hard chocolate outside, and a creamy/cakey filling inside.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Seldom Seen Member
I understand.
Why do things that happen to white trash always happen to me? Got nachos? |
Information Junky
That's not a torsion failure. . . more like reverse-bending fatigue. That 944 shaft, OTOH...
oh, and keep in mind that the key (in the keyway) likely provided support. ..it's not always so simple to point to corners as stress-risers. YMMV
Unregistered
LOL, I have three pieces just like that on top of my file cabinets in my office.
With just looking at the picture I don't see a stress riser or significant material flaw other than the keyway. My guess is it endured too much radial load from misalignment causing it to bend at ever revolution which work hardened it until it became too brittle and sheared. Have you run any hardness tests on it yet? |
We need to know more about the material. Was it heat treated, and if so, was it a through-hardening steel or was it only surface hardened? It has discoloration of a pretty uniform depth around the diameter, which appears to follow the contour of the keyway as well, indicating it may only be surface hardened.
The keyway itself does not appear to be an issue. The bottom corners are well radiused for the size of the keyway. I only see one little crack propagating from the keyway, from the left side, and it appears as though it way have been a result, not the cause, of the failure.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Unregistered
hint...
The dark portion of the fatigue fracture surface exhibits classic “beach marks”, “thumbnail marks”, “stop marks” and are clearly present in the darker portion of the fracture surface, the light portion of the fracture surface is where "fast fracture" (final separation) occurred. A common rule is Bright = Brittle fracture. Dark = Fatigue fracture.
Mike... Don't take this the wrong way but.... You wear a Pocket Protector don't you?
Unoffended by naked girls
He keeps his pocket protector in a pocket protector.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
Model Citizen
He has a good pocket protector he wears to church.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
