trans fluid milkshake
my 740 volvo auto just did a odd trick
the rad coolant leaked into the trans fluid creating a milkshake oil is fine just the trans fluid and coolant are mixed flushing the coolant is eazy and I have a 240 auto rad to swap in [looks the same as the 740] but how to get the milkshake cleaned out of the trans ?? or is the trans toast and needs a swap ?? I have seen lots of oil+coolant mixed milkshakes from bad head gaskets but this is my first time for a trans fluid milkshake any ideas ???????? |
contamination from dihydromonoxide.
Not much you can do except drop the tranny pan (if a volvo even has one) and change the filter and then flush it several times. |
Bad deal - below is a pic of a piston from a John Deer 4455 tractor. The engine developed a micro crack and a small amount of coolant made its way to the oil galley. Once there it set up a nice reaction to seize the piston and allow for pre-detonation to occur. The result....BANG! and about $12 large to fix and a nice 'hand grenade' part I use for training.
http://forums.pelicanparts.com/uploa...1283272085.jpg |
| All times are GMT -8. The time now is 07:25 PM. |
